- Mar 21, 2007
EF2 would be a nice choice if you're looking for a hybrid with usb dac. EF1 goes pretty nicely with the K701 from what i have read.
Originally Posted by calvinjai /img/forum/go_quote.gif From what i understand, you can use a DAC instead of a soundcard and vice versa. I don't believe you can use both at the same time. So if you got a compass, you can use the usb dac and skip out on the sound card. For amp combinations: http://www.head-fi.org/forums/f5/var...01-2-a-434774/ |
Originally Posted by DJ taka /img/forum/go_quote.gif the EF1 looks nice, but it would need a DAC to go with it correct? |
Originally Posted by DJ taka /img/forum/go_quote.gif and the EF2 looks pretty good as well, since it's USB that is pretty much I will need correct? |
Originally Posted by DJ taka /img/forum/go_quote.gif since my source is PC only. The iBasso D10 looks promising from what I've read as well, all are pretty inexpensive as well which isn't too bad. |
Originally Posted by charlesyu /img/forum/go_quote.gif you should forget about sound cards and get an external DAC, the noisy environment inside a computer is really not suitable for audio conversion, so no matter how good the sound card is, the "sound" is not going to be great |
Originally Posted by RicHSAD /img/forum/go_quote.gif I don't hear any of the noise you speak of coming from my Essence STX. I'm not gonna claim that is it better than an external DAC costing twice as much, but it still sounds great and all I hear is pitch black when nothing is playing. |
Originally Posted by anetode /img/forum/go_quote.gif I'll do you one better: the Essence STX is better than most amps costing twice as much, definitely better than the Compass and Zero DACs. Lower noise floor too, as in it filters a 12v rail from the power supply instead of sucking of the motherboard. Measurements: Two in One: Asus Xonar Essence STX Sound Card Review (page 7) - X-bit labs |
Originally Posted by Acix /img/forum/go_quote.gif Maybe you can elaborate more.. |
