tumburu
- Nov 4, 2012
Had them for over a year now and the cable is fine. However, I'm really careful with it.
Agree with akg3003 sounding really good, I still listen to it every night even after owning it for about a year. It's my reference IEM and I alternate between 1p2 and akg3003. No problem with cable so far and sometimes I slept with it. Pop in and out much easier than 1p2.
X2 ..sparrow is really spot on this one.. (I know his spirit lives on here)..
still rockin' 'em with the lowly iphone.![]()
Most of the time I listen straight from the iPod. The gains in quality when I tote out the -dB and RSA amps just isn't worth it sometimes.
1p2 and 3003 are my go to phones right now. They cover all my genres.
Just a question Dr No. What model was the K3003 - with the volume control or without? If it was the model with the volume control, did you use the additional 3.5mm converter plug into a 6.5mm jack? Plugging the 3.5mm jack into a 6.5mm plug without the converter will lead to impedance imbalances - pretty much sounding as you described, ie extreme treble and poor bass.
I suspect you may need to retest to get a better appreciation of the k3003s.
Regards,
Giles
