HiWire
- Mar 26, 2004
Uh oh... time for a new source and amp. A Head-Fier and his/her money are easily parted
Originally Posted by Jan Meier Dear Headfellows, these phones are very insensitive and need a high signal voltage. They, for instance need considerably more signal than the HD600 and HD650. Jan |
Originally Posted by Jan Meier However, I would like to give a warning to all those who intend to buy these new AKG phones. Despite their impedance of just 120 Ohm these phones are very insensitive and need a high signal voltage. |
Originally Posted by trbl And the specsheet for the K701 rates it at 105 dB/V, or about 3 dB higher sensitivity than the HD600. Is the published K701 spec wrong? |
Originally Posted by rsaavedra If I understand this correctly, it seems the K601 will be harder to drive than the K701? |
Originally Posted by Jan Meier ... You need a source of decent output voltage (2 Volts) and an headamp with adequate gain factor (x5 is barely enough) otherwise you will be very disappointed! |
Originally Posted by taymat Dam so both these headphones will need a really good amp? Well that doubles the purchase price then. |
Originally Posted by Jap [size=small] [...]even the closed K271---require amps with gusto.[/size] |
Originally Posted by Jan Meier However, since the K701 has less bass-impact than the HD650 the latter produces more "WOW-effect" at lower sound levels. |
