tinyman392
Be nice to noobs, we were all noobs at one point in our life.
- Apr 27, 2011
Yeah, but they don't support Spatial audio still.Netflix has had ATMOS available for along time.
As I said previously, and just to be clear, when you have spatial audio output then you are using an Apple defined codec. (see previous)Netflix doesn't support it yet... Last checked, they don't have plans to.
Well everything through the AirPods Max will be re-encoded to AAC anyways. Unless you're wired using the adapter cable.
I think I might of given you outdated info regarding the output voltage. Last time I read about that was a few iOS versions back…….Thanks for coming back to me! I’ve got Shure SE215 with impedance 17 ohms and sensitivity 107 db. My iPhone is an EU one.
Yes yes I know, that’s why I wrote 24/48. While I cannot say there is a huge difference from AAC files over wired headphones, I can hear a definite improvement with lossless and wired iems. Still I prefer the APM sound overall though!The Lightning dongle is lossless, but not the hi-res lossless.
Thanks a lot for the update. There has never been volume output limit on any UK iPhone. I have had 2 British iPhones in the past and they had no limit. My current EU one though has it for sure. But still, wired iems present plenty volume output even on the capped iPhone so it does not seem to be a problem!I think I might of given you outdated info regarding the output voltage. Last time I read about that was a few iOS versions back…….
Living in the UK post Brexit it’s hard to know what our phones and dongles output anymore so I did a little experiment. Within ios14 you can set the volume level to a maximum of 100db manually. Using my HD660S (120 ohm open back headphone ) when I turn this OFF (no limit) and turn the volume to maximum it gets very loud, my comfort(listening) level is about 2-3 clicks from max volume like this. When I turn it ON and set it to 100db I would say it it’s the equivalent volume of about 2 clicks from maximum when it’s turned OFF.
I’ve not got the equipment to test the voltages but this would suggest that there is no 0.5 v limit being applied to the lightning dongle here in the UK anymore based on my basic experiment.
(I think the limit is applied manually when we turn on ‘reduce loud sounds’)
basically, if my HD660S can get very loud on the dongle here in the Uk then it’ll have no trouble driving your Shures to dangerous levels.
of you want to make sure you have got full output potential though make sure you go into sound/ haptic settings, headphone safety, turn off ‘reduce loud sounds’.
You are absolutely right, I also have said that many times here. It’s not only the sound though, I am always absolutely stunned of how comfortable they are even while being that heavy! I don’t feel the weight at all, no pressure points anywhere. It’s the first time in my life I can wear a pair of over ears practically for ever without having any discomfort! Apple did a marvelous job in the design and anatomical approach of the APM. Add to that a really balanced but still punchy and deep sound and you get all you need from a wireless set.for me these are hands down the best wireless anc headphone I have tried. I prefer APM over Shure Aonic 50, B&W PX7, Sony XM4.
I haven’t noticed anything myself.@tinyman392
Have you noticed any difference in sound on normal stereo tracks with the new firmware 3E756? At first quick listen I thought everything sounds the same but after a more thorough listen I think sound is more balanced, upper mids come through richer, bass seems a tad more detailed and anc seems better with sudden high pitch noises. Is it placebo or actually there?
Ok. I mean the songs which are not optimized for spatial audio. Songs which are the majority in my library and which present no stamp at all, no Dolby and no lossless logo. I believe there are differences comparing to previous firmware.I haven’t noticed anything myself.
I think you’re right. It switches instantaneously so it seems that way.I’m 99% sure the Dolby Atmos being used here is lossy. It isn’t using the same file, the pause between switching is while it buffers the new file.
This is at least one example:Can you please point me to where Apple’s encoding for Bluetooth audio is documented to be 264 Kbps AAC please? (and not the soundguys URL which I‘ve seen). TIA.
That "special sauce" gets lost when not using the APM. I think you are on to something there.I thought that it is worthwhile to make clear what the difference between Dolby Atmos and (Apple) Spatial Audio is with respect to transmission and codecs.
Note (1): You can have stereo input and Spatial Audio output
- Dolby Atmos is a format and decoder that is in the operating system that outputs to the mixer, which is then encoded in AAC to your Bluetooth headphones including AirPods, Bose, Sony etc. Example Apple Music
- Spatial Audio is an output format that replaces the AAC output encoding with Apple special sauce working only on Apple stuff, which allows head tracking and probably other psychoacoustic technology we know little about. Example, Bruce Springsteen's documentary on Apple TV.
Note (2): Dolby Atmos + Spatial Audio may be a different audio experience since one is an input format and one is an output format. This doesn't mean today they are different...
It does make the APM far more interesting and engaging.I think you’re right. It switches instantaneously so it seems that way.
Still not sure I’m sold on Atmos. I like the idea in theory, but the problem with having even the best software replicate an artificial sense of space is that the individual elements seem to have less clarity. I’m not sure I like everything feeling distant. I.e. The open-back Audeze iSine with lossless music would sound better with an open soundstage than the Powerbeats Pro with Dolby Atmos.
