Gamerlingual
I’ll await for others’ feedback.
What does everyone do about the condensation issue?
For those that do have condensation, what is your solution?
Guess it would have to be to dry it with a towel after every use at home. Not very ideal.I don't do anything as I haven't noticed that it caused any issue so far.
But I'd certainly welcome FR curve measurements before / after - particularly since it's deposited on the driver, and it's only in the longer term that we'll truly now whether it poses a reliability risk or not.
All the problems you mentioned you experienced could have been caused by something else.
*sigh* You don't need to do anything. Take them off your head, and voilà they're dry in 5 minutes. Stop over-thinking this.Guess it would have to be to dry it with a towel after every use at home. Not very ideal.
I don’t want the water to get into the drivers. I’m not doing anything to induce annoyance. How you react is out of my control.
I’ll wait and see what others might suggest for tips that are diplomatic. If not, H95 and the Amiron are on my radar.
Angelom is on a crusade. Crusaders mostly don’t care about arguments.This is like preferring Casio over Patek Philippe. Sure, both show you the time, but one is much better. APM has clearly better materials, superb engineering and internal design compared to H95. There's a reason why people find B&O products overpriced (I prefer Sony tvs to B&O anytime). You can claim that H95 sounds better, which is of course subjective in this case, but you cannot say that the quality of internals is not important. Quality materials and good engineering are important in any product. If you say internals don't matter at all, I have a hard time believing any of your comments.
Excellent recommendation. Still listening. If you haven't yet, check out the first few tracks of Yosi Horikawa's Vapor. You might enjoy it. I'm turning into an unabashed Yosi Horikawa evangelist.For those wanting music that demos apm well, I just found this electronic artist who is blowing my mind and the production is amazing. https://tidal.com/album/113460311 or everyone will love. I still think benee and self tape also rock apm best too.
I contacted the Apple support for the condensation effect. They told me to dab the drops with a little towel, that’s all. BTW, the H95 has the same issue, maybe little bit less, but not much. I don’t think that you will get a damage. I use my KEF Space One Wireless for sports and there goes a lot of condensation and sweat inside. Never had any problems.I don’t want the water to get into the drivers. I’m not doing anything to induce annoyance. How you react is out of my control.
My APMs always have condensation because its really humid where I live, and it's common for all my headphones, except for most of my other headphones, it's usually more difficult to remove the ear pads, and not as easy to see the drivers themselves within a few seconds.Meaning it was not meant for some to own. I’m fine with awaiting others’ feedback as you did while I check other threads. Cheers to those who have chimed in
