Excited to order these as my current silicone ear tips make me feel like I'm underwater. My only concern is if they'll fit in the case, as my current one's core is shorter than standard:
A Review of MandarinEs Foam Tips
- Thread starter Julienstanford
All mandarines back in stock but with new trouble. Set now contains SML only combination. I don't need SM - I need 3 pairs of L. Why you change options?
garcsa
Member of the Trade: Mandarines IEM Memory Foam Eartips
- Mar 23, 2011
@dmkboxAll mandarines back in stock but with new trouble. Set now contains SML only combination. I don't need SM - I need 3 pairs of L. Why you change options?
Every question have an answer.
All scroll down combinations will be back soon.
I don't want to boring you with technical details...
Maybe I'll employ you to find troubles....
PM me.
LoneRanger
Symbio W in stock from Thursday.
Thanks for the huge demand!
new product soon...
Going to place an order but can you say when the new foam only tips are going to be available, so I can get some of those at the same time?
el-jorge
@garcsa Is there a size chart? I'm using spiral dots m and ml (m is just too small and ml just too large). And which one do I need for a JVC fw-01?
garcsa
- Mar 23, 2011
Symbio W will fit JVC HA-FW01@garcsa Is there a size chart? I'm using spiral dots m and ml (m is just too small and ml just too large). And which one do I need for a JVC fw-01?
https://symbioeartips.com/termek/symbio-w/
Try M and L
el-jorge
They arrived this week. The L is too large, I should have bought the small instead, my first impression is that the M is also a bit large.There is little bit of pressure on my ear, after a while my ear hurts a bit.
garcsa
- Mar 23, 2011
I have to copy here the next text, from time to time:They arrived this week. The L is too large, I should have bought the small instead, my first impression is that the M is also a bit large.There is little bit of pressure on my ear, after a while my ear hurts a bit.
"The essence of Symbio W Eartips is that the foam part has its own inner force to push the silicone flange to the ear canal walls.
Someone can feel that this force is uncomfortable... This is not an issue.
Also someone can think that Symbios are bigger than usual eartips. They are not bigger.
After a lot of experiments we decided on this density of memory foam. If memory foam would be softer the isolation won't be as good as it is now and our eartips won't be Symbio!"
Sizes (diameter):
Symbio W, Size L: 13.3mm
Spiral Dots, Size L: 14mm
garcsa
- Mar 23, 2011
btw - just one screenshot:
arielext
I have had these been 'tipped' to me while I was on a quest to find the perfect tips for my, then newly, aquired Toneking T88K.
That was about a year ago I believe. These tips are exactly what I was looking for! The symbio-w L fits perfectly.
el-jorge
After some trying I settled on size m spiral dots. The rubber does not put so much pressure on the ear, I probably like rubber tips therefore a tad bigger. With my monster supertips I use the ml rubber, but the m soft.I have to copy here the next text, from time to time:
Sizes (diameter):
I ordered an extra set of small symbio to try those also instead of the mediums. The L is just to large.
ncristia
- Mar 19, 2014
Ordered new foams and the coupon code did not work.
garcsa
- Mar 23, 2011
Try now please, it should work now.Ordered new foams and the coupon code did not work.
ncristia
- Mar 19, 2014
Thank you for the adjustment and taking care of this so quickly. I heard from a trusted source that the new foams are the real deal.Try now please, it should work now.
