Thanks for the comparison. By the numbers, I should be just as happy with Symbio W L as with Final E LL. Yet the Finals seal my ear quite well, while the Symbios unfortunately just do not. (Unless you've changed size of your L in the last couple of years. But I don't think you have, right?)
Do not just think about size. The Finals are a bit more bulbous and the material is a tiny bit more grippy - its serves one great if you tends to push your tips all the way in until you can't push it any further. The symbios are widest at the foot and the material are harder - shape and hardness are two qualities one must bear in mind in working with a certain type of tips. Try not to push your symbios all the way in like your finals - instead leave it shallow and stop pushing when you can feel the widest part entering / touching the entrance of your ear canal. Hold it there for a short while to let the foam expand helps too.
For me L size work best - and is what I'm using with my various iems - but I crave for something between M and L from Symbio to be my endgame tips.
Brings out a bit more detail in the upper mids and tightens up the bass substantially. I’ve also tried combining the spiral dot tips with the symbio foam and it gets a bit warmer and slightly more soundstage.
Thank you @garcsa
