westyjeff
@garcsa I just ordered the Symbio W in MMM & MML, I have to say I was a bit confused on the sizing for these, with MMM, MML, MLL and LLL as size options a little more description on the web site would be helpful.
Thanks for your order!@garcsa I just ordered the Symbio W in MMM & MML, I have to say I was a bit confused on the sizing for these, with MMM, MML, MLL and LLL as size options a little more description on the web site would be helpful.
3 sizes, as usual with eartips.
- S, M, L.
One set contains 3 pairs, your choice which combination. Sizes S is out of stock till mid of March - these datas can read on our website.
Cheers!
I believe that "W" fit IEMs with a wide nozzle; "Wn" are W with an adapter for medium sized nozzles; "Wa" are W with an adapter for small nozzles. W fit IEMs that typically take size 400 Comply; Wa fit IEMs like Shure or Westone that take size 100 (or even slightly smaller).What's the difference between the W / Wn / Wa options? I'm looking to get some to fit the Sony MDR-7550 IEMs. Thanks in advance!
Sonys nozzle diameter is 4mm.What's the difference between the W / Wn / Wa options? I'm looking to get some to fit the Sony MDR-7550 IEMs. Thanks in advance!
Can anyone help me and verify i need the Wn tips for Carbo Tenore?
They have 3.5mm nozzle acording to this pic
Take the Symbio Wn , you'll receive Eartips with adapters. If you'll don't need the adapters you can use them without.
Doubt that the nozzle is 3.5mm .
According to translator: "... 3.5mm gold plated, stereo mini plug..."
Don't forget on coupon code
