Good choices, but what's the first video? It's been geo-blocked on me
Maybe this will work ...
Same singer - different band ...The Creatures
Another me fav - Bauhaus
It's always fun to read manual or technical specs sheet from Aliexpress ! LOLA bit of fun on aliexpress a friend passed it on , she bought it just for fun .
Functions and features:
1. Decoding HD source digital audio signals into analog 5.1 channel audio signals
2. The analog stereo ( R / L ) signal through the audio processing chip, converted to analog 5.1-channel audio signal
3. Two-way SPDIF optical input, 1 coaxial coaxial input, 1 stereo Stereo input, more complete multi-channel digital audio output to bring the switch more convenient
4. RCA output interface, easy docking docking amplifier
5. Multi-channel one-touch switch, convenient and fast, while the stereo and 5.1-channel switch
6. Sex noise ratio: 120db
7. Resolution: 80db (1 KHz )
8. Response frequency: 20Hz ~ 20KHz +/- 0.5db
9. Analog output level: 2.2V
10. Product appearance size: 105 × 75x25mm
That is loud sex .
That is loud sex .
For play time approx 2 hours - minimum you need analog output level 10V/20mA imhoI'm sure you can knock 30 dB off that by moving the headboard away from the wall, shutting the windows and drawing the curtains. Even 90 dB is likely to cause damage though, so keep it under two hours for the sake of everyone's hearing!
