nick_charles
- Feb 26, 2008
Some odd findings:
When I ran FooBar and the ASIO driver for the Musiland the fooBar output was way off. There were deviations from the reference of over 11db at some frequencies, disabling the ASIO driver in FooBar fixed this and the playback was as close to identical to the reference as makes no difference.
When trying to record from lilith into Cool Edit Pro starting Lilith caused CEP to blip nastily, further the recorded file was now 2000 samples shorter than it should have been, I tried this 5 times allowing CEP time to recover but each time the recording came up short.
Will try one more using a 2 PC setup
Frankly quite puzzled by all this...
reran using separate play and record PCs
Foobar behaved itself and output exactly 32768 samples no problem, Lilith output 31260 samples i.e 1508 samples shy of the target i.e about 0.0342 seconds lost from the end. Without knowing more about why this is happening it seems impossible to reccomend this player.
