I hear a bit of static between songs on Spotify and Tidal. Other than that, perfect.
A beta firmware for M11/M11PRO/M15(2020-06-04)
Dear user,I hear a bit of static between songs on Spotify and Tidal. Other than that, perfect.
Which model are you using? Does the issue happen in certain music file or all the time? What's the sampling rate o the songs?
Best regards
veritas2572
Neutron player crashes after installing this beta firmware.
I use M11 Pro. The static seems to be audible only between songs when playing Tidal and Spotify.
veritas2572
Dear user,
Best regards
Newtron player newest version on M11 0604 beta. happens whenever I try to play music
You could try the 0722 beta firmware and check again:
Hello everyone, here comes the latest 0722 beta firmware for M11/M11Pro/M15.
Notice: this version is still under beta testing phase, if everything works fine, we will release the offical firmware next weeks. And if you have any problem, please feel free to contact us at support@fiio.com. Any suggestions would be greatly appreciated.
Download link:
M11->fiio-file.fiio.net/M11-ota-20200722.zip
M11Pro->fiio-file.fiio.net/M11Pro-ota-20200722.zip
M15->fiio-file.fiio.net/M15-ota-20200722.zip
Update note:
1. Added tracks sorting within playlists (now the playlists sorting, which is based playlist names, and tracks sorting within playlists are controlled independently);
2. Improved the MQA identification and playback, fixing the issue where a part of the MQA track would be missing when switching tracks, and also added MQA playback indication on the status bar;
3. Improved the issue where the folders loading would be slowed down when the "Hide un-scanned folders" option is enabled in Scanning settings;
4. Fixed Sony Hi-res application can't be played;
5. Miscellaneous improvements.
Download link:
Update note:
veritas2572
Download link:
Update note:
Did you guys changed android audio FX? Because after installing 0722 I found my VU meter widget from GeorgieLabs not working properly. on 0604 that VU meter widget worked properly. you can find it in play store.
And I hope you add dB unit volume display and battery percentage on-off function. when i say volume unit i mean volume is displayed -xx.x dB instead of displaying just an integar from 1 to 120 on statusbar.
Some statusbar icon not seems to be stock android icon. I was not able to remove battery percentage and bluetooth icon with using SystemUI tuner. Those Icon does not seems to be clean and the space between each icon is not constant. Since M11 and M15 is the flagship in Fiio, I think those minor user interface issue is also important.
I know you guys makes the best audio equipment in china, so I hope you read my reply carefully and review it. thanks in advance.
Dear user,Did you guys changed android audio FX? Because after installing 0722 I found my VU meter widget from GeorgieLabs not working properly. on 0604 that VU meter widget worked properly. you can find it in play store.
We will PM a new beta firmware to you in the next few days. As for the UI feedback, we will report to the engineer for checking about that.
Best regards
hmscott
@FiiO - in the future please post new DAP BETA firmware announcements under a new thread title - and / or add a post to each DAP model main thread, as I didn't have "Watch" set for this old 2020-06-04 thread and I missed this new BETA firmware for M15 announcement until I saw @DKMerx's post here:You could try the 0722 beta firmware and check again:
Download link:
Update note:
https://www.head-fi.org/threads/fii...attery-64-gb-rom-1299-99.920276/post-15765129
BTW, this firmware version did fix the Rate display for UAPP + Tidal for MQA playback.
Thank you for keeping us up to date on BETA firmware updates
ozz007
- Mar 2, 2012
Fiio can I have Viper Hifi in english p!eaxe
When Tidal issued the update Tuesday, I was disappointed not seeing the full unfolding of MQA on my M11.
But then, I switched from the "Master" settings on streaming and downloads to the "Hi Fi" setting - like if you have an MQA DAC and you need to bypass the software doing it (and keep the application from doing the first unfolding).
And, it seems to work! The MQA indicator shows up at the top. But, for some reason, not on all tracks. All of the classical 2L titles that I checked seem to unfold to 352.8kHz! Some of the biggest new releases like Taylor Swift's also seem to unfold at 44.1kHz like with UAPP, with the MQA indicator on top. I've checked around on random MQA albums from different labels big and small. Some work but perhaps the majority don't - no rhyme or reason.
Here are some screenshots. The last album's an example of a newly released Master album that does not trigger the MQA indicator:
Dear user,@FiiO - in the future please post new DAP BETA firmware announcements under a new thread title - and / or add a post to each DAP model main thread, as I didn't have "Watch" set for this old 2020-06-04 thread and I missed this new BETA firmware for M15 announcement until I saw @DKMerx's post here:
Thank you for keeping us up to date on BETA firmware updates![]()
The beta firmware will be posted by our engineer in the Facebook club first. You could also join it if you have a Facebook account: https://www.facebook.com/groups/1615065175446865/about
Best regards
Dear user,Here are some screenshots. The last album's an example of a newly released Master album that does not trigger the MQA indicator:
For the MQA support in Tidal app, you should contact Tidal for releasing a new version for the issue:
We have added global MAQ support since beta0604 (now the player supports 8x MQA unfolding even when playing MAQ tracks in third-party apps. However it not include Tidal, Tidal will update a version to adapt our product later)
Best regards
veritas2572
Dear user,
Best regards
how long should i wait for the new beta firmware with my suggestion applied?
- Home
- Forums
- Head-Fi Special Forums
- Premier Sponsor Forums and Sponsor Forums
- FiiO
