A beta firmware for M11/M11PRO/M15(2020-06-04)
post-15773851
Post #76 of 86
sabloke
Who would have thought Facebook is any good? :D From FiiO-philes club
Get an early access of the M11/M11 Pro/M15 official firmware
Note:Due to some small issues of our file server, the auto firmware push will not start until next week.
Download Link:
M11-> fiio-file.fiio.net/M11-ota-1.1.0.zip
M11Pro-> fiio-file.fiio.net/M11Pro-ota-1.0.3.zip
M15-> fiio-file.fiio.net/M15-ota-1.0.3.zip
Update Note:
1. Added global MQA support, and improved the MQA playback;
Note: When scanning for tracks, the app will detect whether the tracks are MQA or not, which may slow down the scanning speed if you have MQA tracks in your library.
2. Added displaying sample rates on the status bar (you can enable it in Settings -> Display -> Display sample rates);
2.1 This function is only available when playing music locally, and it does not work for the USB DAC, Bluetooth, USB Audio modes;
2.2 When playing MQA tracks, the status bar will display the original sample rates of the MQA track instead of the playing sample rates after fully unfolding, as requested by the MQA licensor.
3. Added 'enter sleep with one click' function (you can find the 'enter sleep' icon on the home page and tap on it to have the player enter sleep mode);
Note that when this function is performed, the player will also close the apps running in the background and turn off the screen to enter sleep mode. After that it can only be woken up by pressing the physical button;
4. Added support for screen rotation (can be set in the pull-down menu or in Settings -> General. The screen will rotate upside down when this option is enabled);
5. Added Eye Care Mode (can be set in the pull-down menu or in Settings -> Display);
6. Added battery level and volume level display for USB DAC, AirPlay and Bluetooth receiving modes;
7. Added quick-charge indication and charging animation (displayed in the lockscreen when connected to charger);
8. Added a new function of hiding the un-scanned or empty folders in Folder view menu (can be set in FiiO Music -> Settings -> Scan for music. When enabled, only the titles of the scanned tracks will be displayed in Folder view menu);
9. Added 'File size limit for album art' function (can be set in FiiO Music -> Settings. And after selecting a limit, the album art image whose file size exceeds this limit will not be displayed);
10. Added album art display in Folder view menu;
11. Added two new options to the Multifunction button setting: Play/Pause, No function specified;
12. Fixed the issue where the input keyboard would be changed to the default keyboard after waking up the player with one click;
13. Fixed the issue where the DSD tracks could not be played in DLNA mode;
14. Fixed the issue where the Google account data could not be backuped;
15. Improved the Channel balance adjustment and increased the adjustment levels to 20 levels;
16. Miscellaneous improvements on performances.
if you have any problem, please feel free to contact us at support@fiio.com. Any suggestions would be greatly appreciated.
post-15775216
Post #77 of 86
Dixter
excellent FW update... Thanks...
post-15777070
Post #78 of 86
Mark-sf
California
California
So far this firmware is stable and has fixed the Airplay sync problems that i was experiencing in earlier betas.
post-15779949
Post #81 of 86
TonyMhz
Italy
Italy
Excellent firmware, for now no problem to report 👍🏻
One question, when the official one comes out of the fiio site, do I have to reinstall it or is it the same?
Thank you .
post-15779972
Post #82 of 86
raykkho
Thank you .
The 1.0.3 is already the official one, the link is just a heads-up for this forum and may be others, I don't see any reason to install it again.
Reactions: TonyMhz and sabloke
post-15780026
Post #83 of 86
TonyMhz
Italy
Italy
Thank you Raykkho!
You have been very clear and kind!
Reactions: raykkho
post-15782099
Post #84 of 86
illbegood73
I've just installed the new firmware on my M11 and just found a very annoying issue: the scan speed is very very very slow! It has always been slow but now it's so much slower than the previus versions! it's taking HOURS to scan about 22000 songs! I want a fix or my money back!
post-15783537
Post #85 of 86
Mark-sf
California
California
By new firmware are you referring to 1.1.0. My scan of 7000 sounds took about 6 minutes. I am using a Lexar High-Performance 633x 512GB microSDXC UHS-I Card. Which card are you using?
post-15790004
Post #86 of 86
FiiO
Sponsor: FiiO
Guangzhou,China
Guangzhou,China
Age
13
Website
www.fiio.com
Dear user,
Or you could try to reset the media library and check again?
Best regards
https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official https://www.instagram.com/fiioofficial/ https://www.fiio.com
Users Who Are Viewing This Thread (Users: 0, Guests: 5)
