$999 Calyx M with DXD + DSD, 64GB + SD + µSD storage
Nov 16, 2019 at 3:36 PM Post #5,791 of 6,549
With x-batt and a selfmade leather case since I didnt find one to purchase.
the advanced battery life is really enjoyable :)
X-Batt is a must with the Calyx M. The extra cost is meaningless and the added comfort just enorm. Nice case btw.
Nov 16, 2019 at 3:39 PM Post #5,792 of 6,549
Annoying thing is my current one doesn't work but it's in mint condition
Nov 16, 2019 at 3:44 PM Post #5,793 of 6,549
Where did you buy it? New or used? What about warranty?
Wait that night, charge it.
We will see tomorrow
Nov 16, 2019 at 3:47 PM Post #5,794 of 6,549
Got it from jaben about 1.5 yrs ago. Yeah I'll leave it charging all night and hope for the best
Nov 17, 2019 at 1:57 AM Post #5,795 of 6,549
Nah, it's still not working. Think it's a goner
Nov 17, 2019 at 2:27 AM Post #5,796 of 6,549
Did you try to reset the calyx?
3. Press and hold power and previous button
4. After white Calyx M logo flashing out, release buttons
5. After white Calyx M logo flashing in again, press and hold power and previous button then and release previous button after 1 second
6. After recovery menu boots up, release power button
Nov 17, 2019 at 2:55 AM Post #5,798 of 6,549
Send it to me for look before buying another Gaz.
Thanks nayparm. I need to send you that xuelin back. Sounds bloody good btw
Nov 17, 2019 at 3:28 AM Post #5,800 of 6,549
Lol how could you forget it with the rubber circle glued on!?
I think it could be battery. No warmth when it's plugged to charge.
If it's ok, ill send it to you to see if you can fix it.
Nov 17, 2019 at 3:33 AM Post #5,801 of 6,549
Best mod ever for that wheel :ksc75smile:
Sure no worries, I'll take a look mate.
Dec 17, 2019 at 7:54 PM Post #5,802 of 6,549
Just got mine, charging seems to take a long time... How long do you guys leave it charging with the X-Batt module?
Dec 18, 2019 at 6:59 PM Post #5,803 of 6,549
Ok, so I got it fully charged. Put some music on it and let it rip.
This thing is mind blowing... I never thought there would be so much difference from this to the ZX300. It's insane, just... wow.
Dec 28, 2019 at 4:34 PM Post #5,804 of 6,549
I have been meaning to ask for a while - Just out of interest -was wondering if anyone had pulled apart and examined the audio circuitry- while nothing is mentioned in the manual the calyx m appears to run with 3.5mm trrs balanced cables with good performance
The m-jack that came with player in later batches has a 4 pole trrs but does not work with a balanced 3.5mm cable -while same cable works when connected directly
I have used the 2.5mm to 3.5mm balanced adaptor I use with zx2 and plenue s and these all work well - just don’t recall anything mentioned in this forum regarding this - however if you have 3.5mm balanced cables it is handy to be able to use directly - don’t know if the set up is similar to the zx2 or if there was some attempt in design stage to have balanced - anyone have any info on this ?
Jan 4, 2020 at 4:27 AM Post #5,805 of 6,549
Calyx M review by Mikhail Khilko for Porta.Fi​
Of course, this DAP isn't new, but it's still an interesting option. Our guest author summarised his thoughts about Calyx M
English: https://porta.fi/calyx-m-player-review-white-note/
Russian: https://porta.fi/ru/obzor-pleera-calyx-m-white-note/
not a tempting review to think buying it when you described the sound, to overlook all the negatives of this dap to buy then the sound must be awesome and I did not get that sense from your review
