Surf Monkey
- Nov 7, 2011
Well, it's been a week with the Timeless as pretty much the only thing I listened to. Gave them about 50 hours of burn in, swapped the stock cable for a graphene cable and played with tips.
I am utterly blown away with how good these things sound. Just cannot believe I only spent a few hundred dollars on these.
Found them more sibilant than I liked right out of the box but the burn in and cable have helped tame that. The foam Comply tips lasted about 2 nights before I switched back to a good fitting silicon tip. I found the foam really toned both the bass and highs down more than I liked and took away from the fun and the V signature of the Timeless.
Thank you to all who helped me get these set up.
I never jumped on the Timeless and now, with rumors pointing to a Timeless 2.0 I’m inclined to wait. Good write-up! If the 2.0 doesn’t emerge I’ll probably grab a set of these eventually.
