$350CAD HERUS: Asynchronous USB Audio 2.0, 24bit 352.8Ks/S, DXD and DSD64/128, 2.4VRMS Headphone DAC
Dec 8, 2013 at 8:48 PM Post #77 of 326
HI,
I have few good RCA interconnects and would like to connect the 6.5 mm output of the Herus
to my headphone amplifier? do we have a good quality connector for this purpose? 6.5 mm male to two female RCA's
any link will be highly appreciated. I don't want to spend more bucks on those audioquest or
crystal cable that can do that.
Dec 9, 2013 at 4:19 AM Post #79 of 326
Dear Seeteeyou,
Thanks so much for the link.
Which one will you choose as the best buy one : price performance
or the best one if the price is not to high I plan to use stereovox cable on this connector
Dec 11, 2013 at 4:08 PM Post #80 of 326
Got my UERMs last night and find them much better for listening than the JH16s.
I had a chance to do a side by side with the Herus, Audioengine D3, Audioquest Dragonfly V1, Centrance DACport, Meridian Explorer (revision), the Apex Glacier by itself, and the ODAC > Glacier. The Herus had more hiss than all of the others. It really made quiet passage listening for classical music unbearable. I used Jean-Guihen Queyras doing Bach Cello Suites as my test. The recording is super clean and you can hear when he takes breaths or even shuffles around. At low volumes, the noise floor on the Herus made a lot of that detail inaudible.
Dec 11, 2013 at 11:17 PM Post #81 of 326
I find this rather surprising 'cos I couldn't detect any hiss in my Herus. However in the various Glaciers that I demoed (admittedly in a different time) I could detect some hiss although not enough to be annoying.
Dec 12, 2013 at 12:54 AM Post #82 of 326
What IEMs were you using?
I was using Audirvana+, I'll try it with Jriver at home tomorrow.
I'll plug it into the iusb as well to see if something's going on there.
maybe my herus is defective?
Dec 12, 2013 at 1:24 AM Post #83 of 326
Could be.  Or maybe you're just highly sensitive to noise (or, alternatively, my ears are shot because I'm older than fossils).  As you know from our other communications, I don't find the noise floor of the Herus to be problematic with UERM, even with very quiet passages such as the opening of the SFS Mahler 1.
Dec 12, 2013 at 2:13 AM Post #84 of 326
I was using primarily my TG!334 which is supposed to be very sensitive to hiss. Setup is as follows :-
iPad Air -> CCK -> Type A->B -> Herus -> 1/4"/3.5mm -> TG!334.
Thinking about it, wonder if the 1/4"/3.5mm would mask the hiss.
Dec 12, 2013 at 10:03 AM Post #85 of 326
The FitEar F111 is the only one I can hear hiss with but it's very, very low and I can only hear it when music isn't playing. In fact the F111 is my favorite pairing. It really sounds excellent.
Dec 12, 2013 at 10:04 AM Post #86 of 326
I don't see why it should. For what it's worth I'm experiencing little to no hiss on my unit, though I haven't had time to try it with a lot of different IEMs yet. But so far with the few I have tried it's almost completely free of hiss.
Dec 15, 2013 at 2:01 AM Post #89 of 326
You should do a writeup comparing all those usb dac/amp that you tested.  It would be good to let others know how they sound different from each other.  There are so many choices these days in this segment.
