chrisdrop
Thanks for the response. And your video was hugely helpful, thank you for that too.
I know there's a general range of cost for the GOTL, but it's still a bit unclear what those various options are. Is there anywhere in this thread where I can jump to that? Also, it seems that over time, some options seem to be stated as "must haves" while one or two others are considered less so. Getting such user feedback from experienced owners would be fantastic, as I look to work with Glenn on my own personal configuration. That's the main thing. Hope that makes sense.
Here is a quick basic summary for GOTL (there are other amp options!):
- Transformer: Lundhal transformer or American transformer. (Lundhal is probably a "better" transformer)
- Rectifier: Tube rectifier or HEXFRED rectifier. I think Glenn recommends the American non-Lundhal transformer w/ the tube rectifier. I think the Lundhal + HEXFRED is quieter noise-wise.
- 2,4, or 6 output sockets. More tube rolling options.
- Which input sockets; Minimally 1x 6SN7, more commonly 1x 6SN7 + 2x C3G, or more recently 1x 6SN7 + 2x 6J5. This is, I am quite sure, a topic to discuss and more options are likely possible.
- Goldpoint stepped attenuator (the volume dial, impacts the sound - not just a pure aesthetic). I have, recommend.
- 6/12/25v switch (allows using different voltage tubes, often you can get popular tubes with different voltages cheaper). Very recommended.
- Upgraded capacitors (I don't have)
- Preamp-outputs (I have/ don't use)
Best,
Chris
