Nice tubes. You always have great tubes ... and headphones ... and other kit!
@GDuss asked earlier about some grey glass GEC 6J5Gs that I was using lately, how they compared vs other grey glass GEC 6J5s. The tubes pictured here have vertical clear lines in the grey glass towards the top of the tube.
I have 2 grey sets. The ones which have horizontal lines in the grey glass sound different than the ones that don't have those vertical lines. To be clear, I am not suggesting the lines influence the sound, but that there is something otherwise different between the tubes. Both of the sets that I have are grey glass, so I can't see into the valve to see what is different. I think the ones I have without the vertical clear lines in the grey glass are more clear and crisp, but with less thump and the ones with the horizontal lines have a bit more bass kick. I think the vertical lines are older tubes FWIW, but I am not 100% certain.
Another possibility, the horizontal clear lines tube may be older and "less-NOS"/testing worse - perhaps more distorted? I am not sure if tubes get noises as they "test worse" or if they can also get more distorted (while still being basically quiet). Anyhow, misc musing for you all...
