mordy
- Aug 8, 2010
I found the album on YouTube but just type in Wood after the name (not Wood II)drats, couldn't find the album on Tidal
/sad
/sad
Hello Peeps...
Been a warm summer, been busy with lots of outdoor projects. Fired up the GOTL this evening, to make sure it still works
And happily, it does.
Using the simple tube set of an NOS Visseaux 6N7GT driver and a pair of Mullard 6080's as powers....HOW SWEET IT IS!!!
If we have any Acoustic Bass aficionado's reading, may I suggest:
Artist: Brian Bromberg
Album: Wood II
Listen carefully, kids, and all your hopes and dreams might just come true
Cheers....
/sad
Momentarily changing the topic... Picked up a somewhat rare 5U4G. This one was manufactured by Ferranti, which was a British electronics company that operated for over a century, from 1885 until it went bankrupt in 1993.
Again, per Glenn, this can be used in the OTL with four or six 6BL7 / 6BX7, but it is not powerful enough to use with 6AS7-type output tubes. And of course, it is perfectly suitable for use in the GEL3N.
I am pleased to report that it lights up but haven't had a chance to audition it. Later this evening I hope....
Ken, how about the GEC U52? I can pick up this locally for $400 aussie dollars. Pins are tight so are the base. Tested very good. Potentially for use in the GEL3N. Worth it?
Should be able to drive most headphones well. It's using 3 Lundahl transformers. Chat with Glenn about the most suitable output impedance of the transformers for your headphones. I'm getting a very specific build, as a I already have "The Beast" (aka Glenn 300B) and I'm also getting a custom OTL amp built by a builder here in Canada.One of the headphones I'd like to drive are a planar @29 ohms and the other a somewhat power hungry new driver type @ 38ohms.
"Worth it' is a difficult question to answer since the way each of us perceives sound is so subjective. But GEC rectifiers are among my favorites and many others have written glowing reviews of the U52, so I would say it is worth getting if the price is right.
400 Australian dollars is equal to about 271 US dollars. Checking eBay's sold listings for the last 30 days, this tube has sold for as little as US$173 to as much as US$458, but most have sold for around US$265. Assuming that the cost to ship within Australia is cheap, I would say that the one you found is worth it.
The 300B amp doesn't work so well with the Stellia though. The Stellia are too sensitive and noise is generated. The 300B is dead silent with the LCD4 (and 3) though.
If your company wants to move to the Cloud, I might be able to help, but I admit hardware electronics is not my day job. I've been trying to read what I can about matching amps to headphones and found this article useful:
https://www.headphonesty.com/2019/04/headphone-impedance-demystified/
"The term ‘rule of eighths’ is used as a rough guide. Divide the headphone impedance by 8, and that is the maximum source output impedance (32 ohm headphones / 8 = 4 ohm maximum source output impedance). In practice, it isn’t that strict a rule and often success can be had with a greater range."
No no no.....
Old tubes are precious non-renewable resources. Only smash it if it is totally unusable!
Thanks for the additional info. The article I referenced at https://www.headphonesty.com/2019/04/headphone-impedance-demystified/ does also talk about tube amps:The rule of eighths is really for SS amplifiers. With tubes you want the impedance to match closely otherwise you don't get power transfer. On SS the relationship between load and source impedance is different and power transfer is not inhibited by the mismatch the way it is with tubes, so the focus there is on getting a good damping factor to prevent unexpected changes in frequency response.
If you have a 32 ohm headphone and your output transformer has a 32 ohm tap then you are all set. This is why some commerical tube amps have a low and high impedance switch and use multi-tap OPTs, otherwise the high-Z headphones like the HD800 might not sound good on the amp.
I can tell you my 600 ohm DT880s sound really bad on the 45 amp, which has a 16 ohm output impedance. If the amp were SS it would not be an issue.
"The load impedance of a pair of headphones also plays an important, and closely related, role in an amplifier’s distortion performance. The operating voltage and current (or bias) chosen for transistors or tubes in amplifiers is optimized by the designer for low impedance loads, high impedance loads, or a compromise of the two."
but did also state "Lots of opinions fly around, often contradictory".
At the end of the day, I'm going to let the expert decide (i.e. Glenn) and if Glenn also says the output transformer should have a 32 ohm tap, then I'm going to go with that. Asking these questions has helped with my learning, so thanks again for the additional info.
