Phantaminum
The weekend is here and that means it’s time to settle in, listen to some great music on the Ceasar, and enjoy some fine whiskey.
There isn't any. You need to contact @2359glenn directly.I can’t find a website to see models and pricing ?
Howdy, would just like to ask what are the rectifier tube options that one can pursue for this amp?
I've seen 5CU4, GZ32/5V4G and GZ34s mentioned in various posts.
I've just gotten in line for a GOTL next year, trying to figure out what I should be on the lookout for lol.
Appreciate any guidance, thanks in advance...
any rectifier that can provide at least 250 milliamps
I just plopped in the fuel rod for the nuclear reactor that Glenn sent with my amp.
Cool I am using the 5U8C in my old amp. That is the only rectifier that won't blow up charging two 4700uf filter caps.
Can't even use any other rectifier it has the crazy Russian socket.
Crazy using those caps but I wanted total silence was nuts at that time money no object.
From Deyan: "Since the 12SN7 has a dual cathode and FDD20 has one cathode for both triodes and we don't know the value of the cathode resistor if i connect the 2 12SN7 cathodes I'm basically halving it's value. So since we are in the dark ill put a switch on the thing so you can choose whichever setting suits you better. This is the only way i can guarantee proper operation. In case you want it in the switch in the up position uses both cathodes so 1/2 cathode resistor in the down position is with one resistor. You can ask Glenn if he uses one resistor in the amp or he uses 2 resistors."
What do you think @2359glenn?
The adapters look great. And now that the Canadian postal strike is over I should get my adapters in a few weeks.
