UntilThen
- Jun 16, 2015
I said that I will post some impressions of 3 different drivers paired with 6 x GE 6bx7gt. Well here it is. As always, they are my impressions, my ears and my gear, which is Yggdrasil and HD800. As a matter of interest, I also use my modded HD650.
Siemens c3g - The most revealing of the lot. There is an emphasis on treble sweetness and mid-bass punch. Very dynamic and energised. It's a very engaging tone but I don't think you want to live with just this set of tubes alone. You probably wouldn't because if you have GOTL, you would want at least a few sets of different tubes because our ears crave a change of tone every now and then.
Philips Miniwatt FDD20 - a very good driver. One that I have not highlight enough because I have far too many good drivers. It's quite similar to a Visseaux 6n7g but is more 'full' in tone and the texture is more organic. Treble extension is very good but it can sound sharp at times. Bass punch is good. All the ingredients for a good driver.
Telefunken EL11 - having listening to the above 2 drivers, the most apparent change when listening to the EL11 is the dip in treble sharpness. making my hd800 very comfortable to listen to. There's no lost in details, just not as sharp as the other 2. Vocals sound bigger and mids are more focused. I said before that EL11 sounds like big speakers whereas my Sylvania 6sn7w metal base sounds like my small super monitors. This gives some idea of the change in soundscape. FDD20 sounds bigger than 6sn7 but is never anywhere near the EL11.
Bottom line is I like the EL11 but I would not be satisfied to live with that as the only driver because there are just too many good sounding tubes for the OTL amp.... and my ears likes a change of tone every now and then. I suspect most of us do.
