Band-aid for microphonic tubes and humming?
The GOTL is much more sensitive than my previous tube amps and you need good tubes. Some tubes that never exhibited problems in the past are microphonic in the GOTL.
Did some research. Some people claim that those little silicon rings help (a couple of bucks a piece for audio use, but should cost much less for say automotive use), while others claim that they don't work. Then there are fancy tube damper set ups that cost much more. Some swear by them and others at them....
Found a youtube video where a guy claims that a high temperature silicon repair tape helps better than rings for microphonic tubes, and besides, it is much cheaper.
And if it didn't work, maybe I could use it for fixing something in the house or in the car. Paid less than $2 from China for a roll.
This tape is not really sticky, but if you peel off the backing it sort of fuses and melts together with the other end of the tape. It is flexible and stretchable. To use it on a tube you measure out the circumference of the tube and cut off a piece smaller than that since you want to stretch it for a tight fit on the glass.
No, this is not a BGRP tube, but a 12AT7 with the tape applied.
This tube hummed audibly, and after applying the tape, the hum was reduced. Did not disappear, but only appeared at a higher volume, making the tube usable.
On other larger tubes it did not help, but there were different problems with those - not hum, but large popping noises and crackling.
So this method of using high temperature silicone rubber repair tape may have some uses. A roll should last a long time and is much cheaper than silicone rings.
Even Mrs Xuling suggested using silicone damping.
