Xcalibur255
- Feb 4, 2008
I have found the Ether to be a nice middle of the road solution that works well enough for everything. It's fast by planar standards so you don't feel like you are missing out on the strengths of the HD800 all that much, and it has most of the bass and some of the more mellow presentation of the LCDs. After upgrading the cable I found the voicing pretty close to ideal for most material. This put an end to switching between different headphones for me. Until recently I think I went almost two years without pulling the Ether cable plug from the jack of the 45. A need to track down the source of an ongoing channel imbalance issue broke the streak finally. I thought maybe that cable I like so much might have been the cause, but discovered to my dismay the actual cause might be much worse than that.
