UntilThen
- Jun 16, 2015
Why does he dislike GE? That's the 1st company I work in.
I have a 5Z4G and the plates look just like the one in your photo. Looks like something to keep an eye on for buyers interested in these tubes.The one I have is clearly marked 5V4G, but from your comment, it would appear that the Brimar 5V4G and 5Z4G plates look very similar. As I don't have an amp that can use the 5Z4G I don't own one.... (But the 5Z4G should be fine in Glenn's EL3N amp.)
The published vdrop numbers I have are 25 for the 5V4G and 20 for the 5Z4G, versus 60 for the 5Y3, so it appears your memory is correct.
It appears that Tung-Sol and RCA did not begin to manufacture 6BL7 and 6BX7 until around 1960. On the other hand, Sylvania and GE manufacture dates back to the early 1950's. So a large number of the Tung-Sol and RCA you will see were in fact manufactured by either GE or Sylvania. As Whirlwind points out, it is necessary to go by construction, rather than the name painted on the tube, when purchasing these tubes.
I have yet to acquire enough Toshiba to try them. And... mixing different brands is against my religion... lol
Glenn needs to recruit me as an apprentice now.
Are you ready to start?
You could start practicing on an OTL using a quad of Tung Sol Graphite Plate 7242 tubes as powers.
But wait, first I have to call in an electrician to install a 30A line to my listening room.....
Haha guinea pig. Nobody wants to be my guinea pig
Nobody minds a small fire.
