UntilThen
- Jun 16, 2015
It would be worth owning the OTL just for the B36!
Haha... I think that B36 will be gone by the next sunrise.
I have found the 6F8G to sound essentially the same as the corresponding 6SN7GT from the same maker, with the exception of National Union. The NU 6F8G sounds different than both the gray glass and black glass NU 6SN7GT, and in my opinion, it sounds better.
So if one already has WWII-era Tung-Sol, RCA, Ken-Rad and Sylvania 6SN7GT, then there is no compelling reason to get the corresponding 6F8G. But again, to my ears, the NU 6F8G is special.
Siemens C3G
Tung Sol 6F8G
Sylvania 6sn7w metal base
I have a pair of used Sylvania 6sn7w bakelite base but they are not super quiet. I'm very fussy. If tubes exhibit a little noise, it bothers me. So I don't use them much.
My top 3 are in no partucular order. C3g does not sound clinical in GOTL. Transparent and revealing but not at the expense of being clinical.
In my opinion, it's the 6sn7w having big shoes to fill, keeping pace with c3g.
Nevertheless both are outstanding drivers in the OTL.
And Sophie is a great name.
C3g back on top! And ECC31 falls off the top 3
So the C3g does not sound 'clinical' in the GOTL and has some warmth?
I am a big fan of 1940's 6SN7W, so the C3g's have big shoes to fill..!
BTW, I am hereby laying claim the name "Sophie" for my amp. She will be beautiful and sophisticated.
So, Sophie shall be her nickname.
Cheers...
Sophie is a wonderful name. A name and amp to love.
Glad you like the name, Luke...
Cheers!!
That's what I will be doing going forward. Having sample most of my tubes, I'm just going to roll with a set of tubes for a week before changing. I have the same tubes as you now. A Tung Sol 6F8G with a pair of Tung Sol 5998.
One month has passed since I got Glenn's OTL amp. It's still a reference grade amp in my opinion. In 2017, I heard quite a few good sounding amps, including the Woo Audio WA5. If I had to start over again with buying a tube amp, it would still be Glenn's OTL. It is unique and robust in it's construction. I could find no fault with the build after one solid month of usage. It's sonics is definitely up there with the best I've heard. Glenn's OTL, to my ears, sounds better than all of them. I've not had the fortune of listening to a DNA Stratus and EC Zana Deux Super. I hope to have the opportunity one day. It will make for an interesting comparison.
Watch out for the water pipes - maybe let the faucets drip. Here it was 12F this morning.My dam heat is out and it is 17deg F or -8 deg C Bad day Sunday the blower motor burned out
and can't get one until tomorrow.
Going to be a cold night.
My amp has a totally different output stage then the La Figaro and FA amps that are both cathode follower outputs.
I run the 6AS7 completely different have a different sound and more drive.
