gibosi
- Oct 18, 2012
Ken have you had any trouble with these adapters.
I like the idea of two rectifier sockets, but not sure this could be done or if there would be room for it...but it is a great idea.
I would like it better than having to use an adapter, just not sure if Glenn could pull it off.
The AZ4 fits pretty tightly in the adapter and sometimes it can be a hassle to extract the tube. The problem is that you are holding the adapter with one hand and trying to pull the tube out with the other. I suspect that if the AZ4 socket was installed in the amp, you could hold the tube with both hands, providing a bit more leverage, which should make it a bit easier.
If you think you are going to have at most two or three AZ4s, buying an adapter for each of them, "permanently" installed, could be a solution to this problem. But of course, at about $20 each, buying a bunch of adapters could get pretty expensive...
The major problem I see with having two rectifier sockets, octal and side-contact, installed in the amp is the fact that 4-volt rectifiers can be found with at least four different bases. So with this arrangement, if you want to roll rectifiers with a European 4 pin base, a German octal base or a British Mazda octal base, you will still need adapters. Or perhaps five rectifier sockets? lol
