Seems mine (S/N 016x) has the annoying creaking issue so will be exchanging them to the latest batch. This is inexcusable for a $2k...
2017 Audio Technica new flagship ATH-ADX5000
- Thread starter seeteeyou
ZenErik
- Dec 28, 2008
Did they not creak before? You’ve had it for maybe a month now?Seems mine (S/N 016x) has the annoying creaking issue so will be exchanging them to the latest batch. This is inexcusable for a $2k...
I don’t think mine creaks, and it’s 017x.
I did noticed for the 1st week or so, the left pivot/joint started acting up (wasn't as smooth), but now its rubbing/creaking whenever I move my jaw. I'm curious what serial # are the ones that are supposedly fixed.
ZenErik
- Dec 28, 2008
I can hear a little noise if I yawn or open my mouth wide. But if I'm just talking it's silent. I don't know. Mine seems pretty alright compared to other headphones I've used.
Looks like I'll be getting an advance replacement by Crutchfield, so no need to wait for them to receive my defective unit. Hopefully I get a 02xx batch.
Really amazing customer service by Crutchfield!
ZenErik
- Dec 28, 2008
Cool, but I'm curious about what the noise you're hearing actually sounds like. If it's what I'm hearing then I hear similar noises on lots of headphones so I'm guessing it's more significant.
Its not really a creaky sound, but more like a very rough rubbing/scuffing sensation that only happens whenever I'm wearing/moving it on my head and its only on the left side. It might not be as bad if you have a small head but my head/hair is big and I adjust my headband 1-2 notch from max.
ZenErik
- Dec 28, 2008
Mine is also 2 notches from max. Big head club... Wooo. I think I know what you mean, but I feel like it can't be the same as the creaking issue that was mentioned before as it seems very minor to me and something I've experienced on various full sized headphones. Not sure though! Good luck with the replacement.
TBH, it is kinda minor but inexcusable for $2k hps IMO and I even bought a silicon lube but I figured I might as well give a replacement a try since I'll be keeping these for the foreseeable future. I remember my Utopia carbon fiber yokes creaks but its nowhere near annoying or audible when worn.
ZenErik
- Dec 28, 2008
I'm really curious about how microphonic my replacement cable will be when it arrives. The stock one is still pretty bad. It's probably just the sleeving, but maybe it has something to do with the headphone design too. It's odd how the cable is so microphonic above the split but not really bad below.
I had the same problem (left side only like yours) and got replacement. Since then, I'm pretty happy with the ADX5000.TBH, it is kinda minor but inexcusable for $2k hps IMO and I even bought a silicon lube but I figured I might as well give a replacement a try since I'll be keeping these for the foreseeable future. I remember my Utopia carbon fiber yokes creaks but its nowhere near annoying or audible when worn.
Ya its definitely the sleeving that's resonating which is weird but I guess its a different type of fiber material than the usual paracord.
ZenErik
- Dec 28, 2008
ToTo Man
Nice! If it isn't too much trouble, could you post a pic of the headphones with one stock A2DC and one ZMF A2DC attached? I'm interested to see how much longer the ZMF connectors are.ADX5000 cable in. Unfortunately I can’t really try it out for another 7-8 hours.
It's nice and thin and light. While I could have gotten a much thicker cable I think it would have been a big mistake for the ADX5000.
And yes. I willingly chose this color. Apologies.
ZenErik
- Dec 28, 2008
Will do. These connectors are unfortunately not made for the ADX5000 so they will definitely be a bit longer. I tested that they fit before sending them over to ZMF but didn't take pictures then. The shrink wrap also makes them look even longer.Nice! If it isn't too much trouble, could you post a pic of the headphones with one stock A2DC and one ZMF A2DC attached? I'm interested to see how much longer the ZMF connectors are.
I hope that someday soon connectors that are perfectly sized for the ADX5000 will be readily available.
