ZenErik
- Dec 28, 2008
I just sent off a pair of A2DC connectors yesterday to ZMF to see what cables they'll fit with. Hope to use them with an Atmos S cable.I'm interested to know what ADX5000 owners are using as a balanced cable? I currently have this headphone on demo with both the stock single-ended 6.3mm cable and the stock balanced 4XLR cable. I'd prefer to use balanced because my amps sound better this way, but the stock 4XLR cable is too thick and heavy IMO and I feel it pulling down on the earcups unless its weight is supported. It's also expensive. I like the lightness and thinness of the single-ended cable. Does anyone know if the single-ended cable is 4-core all the way to the plug? If it is then it should in theory be possible to cut off the 6.3mm plug and solder on a 4XLR. Or will I get better performance with an aftermarket cable?
Here they are: http://www.lunashops.com/goods.php?id=5555
I have confirmed that they fit on the ADX5000 just fine, but they're made for a different headphone. They won't look quite as nice if you're looking closely.
I am not sure about the wiring on the stock single ended cable.
In addition I should note that A-T sells the single ended cable for about half the price of the balanced if you'd like to modify your stock cable but still have an actual stock cable available.
'136500940 CORD ASSY ADX5000 $185.98 each'
Not UK pricing, but that's what I was told yesterday when I inquired.
