FiJAAS
Previously known as DTSxJP
- Apr 8, 2014
I was thinking about getting the PHA-1 for my iDevices but if the PHA-A1 is better I will wait and go for it.
Well this is very pretty at least. The battery life is rubbish though IMO, 6 hours isn't anywhere near enough.
What so you want from a portable quality amplifier with a DAC built in? How is this even an issue?
While I do understand the battery concerns, for some of us they may not matter as much as whether or not this thing sounds good enough to listen to. If it sounds terrible it won't matter to me how long the battery lasts. I won't want to listen to it anyway. Beyond that I only care if the battery will get me through my flight.
We all have to decide what is important to us.
So... Would the fiio e12a be comparable given it is 100$ less?
Okay. In that case, would it be redundant to have Sony A17 player to combo with Pha1a as both of them for dac each? Any benefit to Seserial link two DAC then?
let me make my question clear then.
If one will use portable amp/dac like Pha-1a, there would be no benefit for player like A17 as one would get the same result if using cell as the player?
thank you Purk and Bark for your help.
It seems to me that if I am getting the Pha-1a, A17 is merely used as a storage and player and kind of waste for $300.
If I were to keep the A17 and go with the Fiio E12a, would that be a suitable combo as E12a is just a amp w/o DAC?
As for the DAC on the A17 vs Pha-1a, Pha-1a is much better spec-wise?
Thanks again.
