- Oct 26, 2008
From research it appears the BDP-BX7 is the same as the BDP-s370, but the BDP-BX7 includes an HDMI cable. They are also a little cheaper.
You know, when I think over it, from the 1950's to 1999 storage formats and audio-quality was on a steady rise, the storage format peaked at SACD, and since then we've been declining, and now we have an SACD player for $140 that sounds excellent, and these units used to cost, what, $900+? Yes now I see why it's the bargain of the century =)
I think i'll keep my eye out for the s370. Seems like a solid unit, and although it may not be as great as a dedicated SACD unit, I'm at the point where I'd appreciate the size, functionality and cost.
In addition to sounding good with CDs and SACDs, the S370 can also play back DVDs and Blu-ray discs, plus streaming videos off of the internet.
I am sure the upcoming Oppo BDP-93 (@ $500.00) will sound better than the Sony S370....but will it be 3X better?
Well here's what that HiFi World magazine October 2010 issue has to say about the S370's sound quality:
"the analogue outputs were excellent, clear, crisp and dynamic, but in stereo of course; they did a good job with CD... Digital audio via optical link was full bodied, smooth and easy going but hardly better than the analogue outputs ... HDMI was a little harder in tonal character ... SACD sounded as easy going and luxurious as usual ... "
What were they connecting it to? The impression I get, without being able to read the review, is that it was a home theatre receiver of some kind. You realise that the quality of the digital output would be dependant on the DAC it was being fed to, don't you?
So if I'm getting this right you can only output SACD via digital to a DSD decoding capable receiver? That kills it for me since my amp requires balanced input and the way I normally get it is through digital input into my DACMagic.
Originally Posted by soundboy
/img/forum/go_quote.gif
While it's true that after over 6,000 titles released worldwide, there're a number of multi-channel only SACDs, the mandate of Sony/Philips still holds true for 99.9 of all SACD titles.
No, there are 5 ways to output SACD on this player.
1. 192kHz/24bit analog on the red and white things on the back.
2. optical via the shiny red thing on the back, though quality will suffer.
3. coax via the fat plug on the back, though quality will suffer.
4. HDMI to a receiver in DSD.
5. HDMI to a receiver in 176.4kHz/24bit LPCM.
In reality no SACD player outputs SACD; no more than a CD player outputs CD. SACD and CD are the storage mediums or formats. The closest thing to outputting SACD would be the DSD on HDMI, but no one listens to digital, we listen to an analog signal converted/created from the digital. In the case of the S370 the DSD from the SACD goes through an extra conversion process (DSD to 192/24) before going through the final D/A conversion process. The DSD output on HDMI still has to be converted to an analog signal in a Receiver or Processor. As far as the S370's SPDIF output while playing a SACD goes it depends on how Sony designed the player. If it outputs any LPCM while playing SACD's it is the results of a conversion, or possibly the 44.1/16 from the CD layer (that most SACD's have). Someone who owns a S370 should try hooking it up to a DAC that gives some indication of the sampling rate of the received signal.
