Any updates?
I'm very curious...
while the atlona is virtually guaranteed to work in most setups, at $160 - $260 these devices are too expensive for those of us with limited budgets. i would suggest trying the sony with this device from monoprice instead:
http://www.monoprice.com/products/product.asp?c_id=101&cp_id=10110&cs_id=1011002&p_id=5557&seq=1&format=2#description
check out the features and the specs
at $49 it's worth a try & if it doesn't work for your setup, then it can be returned (along with the sony if u purchased from your local b&m store). this is what i'm going to try.
note: make sure it's version 2; version 1 of the monoprice has been reported as not working properly.
hth,
<edit> just ordered along with some hi-speed hdmi cables
Because I can't buy a $140 SACD player and hook it into my system and it work. I have to either buy a high end player with the balanced output for however much or buy a de-embedder just to make it work at all.
follow-up:
test setup: bdp-s370-->monoprice hdmi switcher ---> hdmi monitor + matrix cube dac/hpa ---> akg k701 / ultrasone hfi780
the s370 was connected to one of the four inputs of the monoprice switcher via a solitary hdmi cable. the hdmi output from this switcher was fed to my hdmi-enabled pc monitor; the digital audio (spdif coax) was fed into my matrix cube dac with internal amp enabled.
i can confirm that in testing with cd and blu-ray that a digital audio stream was "de-embedded" from the hdmi signal via the monoprice switcher in all cases. there were no noise artifacts that i could discern. what i cannot confirm is the resultant input signal rate into my dac since there is no sampling rate display. i only tested a single blu-ray disc (jeff beck live at ronnie scott's) and i can confirm that the sound (& playing, ofc) was fantastic, tho the bass thru the cube's hpa was slightly soft and lacking sufficient impact, imho. i could not locate any sacd for testing digital extraction from an sacd source.
final thoughts -- the s370 is a very good sounding unit via the digital out; i did not test the analog output nor any of the network related capabilities. it does make sufficient mechanical noise when advancing from track to track on cd as to be audible from several feet. i returned the s370 with the thought of picking up the wi-fi ready unit (s570) during the boxing day sales.
i forgot to take pix of the monoprice & sony cabled up...
hth,
