oqvist
- Oct 28, 2004
Well honestly I don´t see why SACD would make a strong comeback. The players are cheap but when average joe see how expensive SACD discs are they may be discouraged. I believe more in the bluray format rather then SACD.
Edit:
Well I ended up unboxing the 370 so the 570 will be returned. I figured I couldn´t stand with wireless that may act up from time to time or have sluggish performance. (1 GB internet ). Impressions so far quite loud fan that seem to be on continuesly? I have seen youtube videos where the start up is about twice as fast compared to the PS 3. But loading Avatar took forever and ever?. At least a minute. Tried Toy Story 3 and it´s loading times was a bit more acceptable.
Bluray of course look stunning. As good as I remembered the oppo or PS 3. It´s the DVD upscaling that is the true test. It also seem impossible to bitstream HD audio? PCM is the only option? I also tried the Ipod touch app. Will take some time getting used to. The simple version where you are supposed to use the touchscreen to drag the cursor doesn´t really work. However seeing that the cheap stock remote aren´t backlit I will probably find some use for it.
Edit:
