ytzelf
- Apr 3, 2011
Hey everybody,
I am new to these forum, write from France and would like to replace my Senn HD238, which were OK for me but way to fragile (broke two in 18months, bent the plug). So I decided to go for a slightly higher tier, with a budget of $100-$200.
These are my criteria
Keeping these un mind I came up with this shortlist :
Is this list coherent and which one would you pick? Also, advices are welcome concerning unlisted phones =)).
Thank you all (and please don't mind the mistakes), without this forum I wouldnt even have been able to come up with a shortlist...
EDIT : Added the Ultrasones
- Has to be portable, will be using it walking, commuting, in the train and (rarely) flying.
- I listen mostly to psychedelic pop (think Love, The Millenium, The Zombies), garage (think 13th floor elevator, Nuggets) and classical (mostly piano). I happen to listen to some other genre (rock, electro, reggae) as well, but way less though. I am Definitely not a basshead and would like a pair that performs on a decent range of genres, and that is fairly detailed (I need that for old garage rock).
- Has to be powerable from my iPhone / iPod Classic
- Not too bulky
- MAX $200
- Design-wise, I love it classic.
- Senn HD238i : obviously no improvement in sound quality over my previous hd238 but the iphone-friendly mic and volume are def a plus
- Senn PX360 : these seem pretty new and I wasnt able to collect relevant datas. Thoughts anyone? Is the cable straight or coiled?
- Shure SRH840 : these ones are acclaimed here, but may be a lil bit too bulky (im searching for portable). I kind of dislike the coiled wire as well.
- Grado SR125i : from what I've read here and there these are an absolute winner for rock music. If anybody tested them on the genres I mentionned before, a feedback would be nice =). They look cheap (especially the foam pads... does a leather-y replacement exist?)
- Audio Technica ES55 : the most portable, some feedback on their comfort and how they compare with the rest sound quality-wise would be awesome.
- Ultrasone HFI580 : added after reading a few reviews, they are portable and within my price range.. Any feedback comparing these to the other phones stated would be great
