Yes not too shabby! Much thanks to your tedious mods and guides! I had it in the back of my mind to mention the four layer foam thing over the ceramic in above post, but while omitting it I was sure you would ask curiously about it!
So yes; peeled of the foam on the pad and peeled of two layers of the ceramic cover padding (no cutting but I might later). This was made with almost no sound testing, just a good mid-way solution I thought, slightly less foam overall but at least something securing and dampening. And you're the right dude to flavor it
ivory with more panache
I'm sure genuin leather soft pads will be sweet. Now the only thing I'm leaning towards is for a possible pad with ever so slightly wider form factor (to match 85mm cup) so it will be a perfect cosmetic fit, but indeed happy with the looks and comfort for now, thanks again.
picture below showing pads/phones tad cramped in case but still easily closable and secure for travel
