1MORE H1707 Triple-Driver Over Ear
Jun 16, 2023 at 5:14 PM Post #1,546 of 1,586
Can somebody link any cable that works with h1707 on aliexpress or anything from EU please? I tried to use search and use old posts but most of the old links are out-of stock now.
Jun 16, 2023 at 7:40 PM Post #1,547 of 1,586
Jul 28, 2023 at 4:08 AM Post #1,548 of 1,586
Has anyone swapped pads on these?
Mine are wearing out and I would love to get something that improves the comfort (and sound quality too?)
Jul 28, 2023 at 6:48 AM Post #1,549 of 1,586
Jul 28, 2023 at 7:49 AM Post #1,550 of 1,586
Check out these old posts from @Slater
His expertise was invaluable. I miss him terribly. He suddenly disappeared a couple of years ago. He was always so helpful.
https://www.head-fi.org/search/1376...&c[thread]=849824&c[users]=Slater&o=relevance
You will find intructions ... he was very thorough.
Thank you.. I remember following his mod thread few years ago, but I didn't pursue any and forgot about this long ago.
I used a very dull butter knife, and levered the pads off a little at a time.
This is what he said when someone asked him how to remove the stock pads!! I'm still unclear and kinda skeptical to proceed as I might damage the earcups..
Jul 28, 2023 at 8:02 AM Post #1,552 of 1,586
Whilst this thread is active, I wondered if anyone could recommend a replacement cable at all?
Just curious.. Are the stock ones (which feel the most rugged) bad in any way?
Jul 28, 2023 at 8:22 AM Post #1,553 of 1,586
Jul 28, 2023 at 2:16 PM Post #1,555 of 1,586
Maybe try a plastic spudger?
Jul 28, 2023 at 6:56 PM Post #1,556 of 1,586
Replacement Ear Foam Earpads Cushion Cover Earpads for 1More Spearhead VR H1005 H1006 PRO H1707
https://a.aliexpress.com/_ExuXp5h
They're comfortable, less hot, sound has more bass and sounds less bright, more V shaped, I prefer it and wish I'd switched pads years ago. Easy to install as they just stretch and slip over the cups.
For removing the originals a spudger, blunt edge cutlery knife or spreading knife
Jul 28, 2023 at 9:37 PM Post #1,557 of 1,586
Thank you @mbwilson111 and @Jon995 . I'll try using a spudger.
I saw that slater recommended the beats studio replacement pads if we wanted the original sound.
Would these work?
Wicked Cushions Ear Pads for Beats Studio 3 - Also fits Beats Studio Pro & Studio 2 (Models B0501 / B0500) | Industrial Grade Adhesive & Ear Conforming Comfortable Memory Foam | Black
https://a.co/d/0hD0QUs
Jul 28, 2023 at 9:43 PM Post #1,558 of 1,586
Would these work?
Yes they work, I tried them first. I had problems getting double sided tape to stay stuck and the pads kept peeling away but that was probably my error.
Jul 29, 2023 at 11:24 AM Post #1,560 of 1,586
Have ordered the geekria velour pads and awaiting delivery.
Should I pry off the pad mounting plate or pull just the pad from the plate?
