1964 Ears Adel IEMs
- Thread starter ads1107
- Tags
- asius-technologies-adel-g1-auto-modules 1964-audio-u8 64-audio-1964-ears 64-audio-a10 asius-technologies 64-audio-u12-universal-in-ear-monitor asius-technologies-adel-manual-adjustable-modules-mam asius-technologies-adel-b1-auto-modules asius-technologies-adel-s1-auto-modules 64-audio-1964-ears-adel-u6 1964-ears-adel-a12-custom-iem
Tulku1967
- Jan 6, 2016
Try to pull the right module out so that it is as far out as the left side. (The rubber seal will keep you) So listen and if the sound is good then only the right module housing will have to be rebuilt.My A12 the right module goes deeper than the left one. And i feel the right side slightly louder than left side. My right ear always feels fatigue after listening. I just contacted 64audio, hope they can do anything with it.
hung031086
I tried and i think it's balanced after that. The problem is the facepate around the module on the right is thicker than the left. So i think it blocked the module and made the sound on the right slighly louder.Try to pull the right module out so that it is as far out as the left side. (The rubber seal will keep you) So listen and if the sound is good then only the right module housing will have to be rebuilt.
- Oct 6, 2013
Got a lot of questions after I mentioned about receiving U4SE review sample, especially the comparison to U6. This turned out to be a pleasant surprise, didn't expect I'm gonna like it that much. Just posted the full review HERE, and will have it soon on Head-fi.
![64audio_u4-se-17.jpg 64audio_u4-se-17.jpg](https://cdn.head-fi.org/a/9987414.jpg)
Dionysus
- Feb 6, 2009
Excellent read twister6 and exactly what I have encountered with the U4SE. They are an excellent Mid tier universal set, that should get a more serious consideration and look for the asking price.Got a lot of questions after I mentioned about receiving U4SE review sample, especially the comparison to U6. This turned out to be a pleasant surprise, didn't expect I'm gonna like it that much. Just posted the full review HERE, and will have it soon on Head-fi.
eldss
- Feb 5, 2015
Nice review as always @twister6 . Any chance you'll review their new premium cable?
They have 2 Premium cables nowNice review as always @twister6 . Any chance you'll review their new premium cable?
eldss
- Feb 5, 2015
yes, the description of the "new premium cable" sounds interesting.They have 2 Premium cables now
It's probably a normal SPC cable.yes, the description of the "new premium cable" sounds interesting.
Hawaiibadboy
BANNED
![20170814_225412_001[1].jpg 20170814_225412_001[1].jpg](https://cdn.head-fi.org/a/9987561.jpg)
Review coming soon.
These are dope.
Acoustic Hawaiian guitars are special on these
- Oct 6, 2013
Yes, will post comments about both of their new premium cables, in a near future. One i received was a prototype which has been improved already in the final production version.
lotech
- Sep 26, 2013
That's good since my original cable fell apart after about a month. Split at the 2 pin connector. Luckily had new cable from Peterek.
- Oct 6, 2013
Yes, I think the original stock cable from last year had some problems due to an issue with a supplier. I can only judge by a new stock cable which I received with U4SE, and it's of a higher quality, and I believe from a new supplier as well.
![64audio_u4-se-11.jpg 64audio_u4-se-11.jpg](https://cdn.head-fi.org/a/9988370_thumb.jpg)
![64audio_u4-se-12.jpg 64audio_u4-se-12.jpg](https://cdn.head-fi.org/a/9988371_thumb.jpg)
![64audio_u4-se-13.jpg 64audio_u4-se-13.jpg](https://cdn.head-fi.org/a/9988372_thumb.jpg)
![64audio_u4-se-14.jpg 64audio_u4-se-14.jpg](https://cdn.head-fi.org/a/9988374_thumb.jpg)
![64audio_u4-se-15.jpg 64audio_u4-se-15.jpg](https://cdn.head-fi.org/a/9988375_thumb.jpg)
![64audio_u4-se-16.jpg 64audio_u4-se-16.jpg](https://cdn.head-fi.org/a/9988376_thumb.jpg)
hung031086
Anyone use A12/U12 with AK70 ? I’m looking for a small dap. It can drive A12/U12 or orther totl imes well. Any recommendations?
- Sep 28, 2016
budget is the shanling m2sAnyone use A12/U12 with AK70 ? I’m looking for a small dap. It can drive A12/U12 or orther totl imes well. Any recommendations?
Or maybe lotoo pico
Lastly not really dap, but what abt ak xb10
