Canyon Runner
+1, my MAM modules are similar.. manufacture defects?
Also, since receiving the MAM, and having to remove the S1, I noticed that the membranes are different between the two S1 modules, one looks right the other doesn't. I'll try to take a picture soon.
I've since talked to @AC1 and it's not a MAM issue. The S1 was able to sit in a similar spot. But I'm curious as to what you mean by one doesn't look like other. The membrane material often may be a bit more see - through than other sections, while still doing the same job. Also anytime a bit of moisture from the ear canal gets onto the membrane, it can slightly discolor for a bit. Sorta like a damp spot on a grey t-shirt.
