I already understood these aspects. You seemed to answer the "what", but not the "why" part. It wasn't really answering my question because I already know what they stand for, but not the point, or meaning. I appreciate the time you took to write that though.
To be ultra clear, I know multiple armatures are used in different places like lows and highs, but what's the point if one really good armature can do it all? Like the Custom Art Music One. Never heard it so I can't really judge, but there must be a downside, right?
I see. Sorry that I couldn't help.
I also do not have that knowledge, but if i think of it from the point of view, where every instrument has its own speakers, compared to 1 single speaker, I kinda understand why it might sound better, but that might be wrong..
Aside that,
Anyone knows the different between A6 and A12? and does a6 still some level of bass? lets compare it to Qi.
heh... I went from my bed watching videos to the kitchen table to type this... This may take a while.
Anyway, All transducer types have their own advantages and weaknesses. Since we are talking about IEMs, I will try to keep it in that realm, but I suppose I'll give a broad overview for now. I'm assuming that everyone knows the basic construction of each driver type, so that's a bit of background that you would need.
Dynamic drivers are great. They are cheap to produce (I'm not talking about all of them, but there is a reason that $20 will only ever get you a dynamic driver), and they are very, very reliable, .and fairly durable. That being said, they are susceptible to resonance, due to the fact that you cannot create a perfectly rigid piece of plastic that thin, so it likes to have internal resonances across the surface that happen due to the diaphram moving. The natural resonant frequency is what creates those humps in impedance graphs for headphones (it's why things like the HD600/650 have 300-500+ Ohms of impedance at different frequencies.) And that can cause the headphones to have strange frequency responses, depending on the output impedance of the amp used.
Planar magnetic drivers, in contrast to dynamic drivers, almost always have laser-flat impedance graphs. That's because they have significantly different resonant frequencies, and their extreme light weight and thin-ness allow them to be supremely flat throughout the lows and mids, since their diaphrams essentially act as drums (hence why they are generally considered dark).
Balanced Armature drivers tend to have some insane impedance graphs, because, well, I'm not exactly sure, I haven't gotten that far yet.
Anyway, due to the small size of balanced armature drivers, they often have trouble with moving large amounts of air (which you need for bass). To remedy this, IEM/CIEM companies often pull a trick out of loudspeaker construction where you use multiple drivers to amplify a certain frequency. If all of the drivers in a section of the crossover (e.g. the four bass drivers in an A12) are all vibrating at the same frequency, and they all move the same direction at the same time, then they are said to be "in phase". This allows them to move significantly more air than a single one would have been able to on its own. That's why you almost always see more bass drivers than any other driver, assuming that they are not all of equal count (I find the A10 somewhat interesting in that regard, since it has two bass drivers and four of everything else).
Now, balanced armature drivers are capable of being VERY, VERY accurate, but as a general rule, they are only able to reproduce accurate sound in a relatively small frequency range, before they fall off at either end. As such, most companies will introduce multiple drivers into their setup (That's also why many consider single BA IEMs to be bass light, and often somewhat lacking in the treble too). The trouble with multiple balanced armature setups, other than their being more expensive, is the crossover. This is why JH audio made such a big deal about their Freqphase thing. It makes sure that the drivers are all in phase with each other (across different sections of the crossover) so that all of the sound that should reach your ear at once, does. Now, from my understanding, a crossover filters out the low frequencies, and sends them to the low end drivers, before sending the rest of the signal on to be further filtered all the way up until the treble drivers get their signal. This (I believe, anyway) is why JH puts their treble drivers so much closer to the tip of the piece, instead of farther back into the shell (this is from what I've heard, anyway, since I have no experience with JH at all). Tuning for that is also very, very difficult, so there's another issue with them. Again though, if you're willing to pay the premium, you get better sound.
I'm sorry if this is rather convoluted, and incomprehensible. I'm rather tired (It's past 2AM) and I didn't actually plan to write any of this... I may come back to it or make a post dedicated to all of this at a later time.
Anyway, if you're not satisfied, I hope that this pair of links will at least help with the understanding of multi-BA stuff:
https://brianli.com/in-ear-monitors-balanced-armature-drivers-vs-dynamic-drivers/
https://jhaudioblog.wordpress.com/2012/09/26/what-is-a-balanced-armature-driver/
(I scanned through these both, and they both were quite accurate in their content, so read up
@yxpoh, I have no real experience with the Qi, but I can certainly say that my A6 is not lacking in bass in any way, at all. If you take a look back in the thread (I think I posted it around September 10th-15th, whatever page that is) I posted impressions of most of the line, since I had gone down to the 1964 lab on Friday the 4th of September to pick up my A6.
@BobFiggins, According to |Joker|, the Music One is a vented balanced armature driver (Interestingly enough, the Final Audio Design Fi-BA-SS also uses a single vented BA driver, although it costs ~5X more). So I would think that the isolation would be somewhat lacking in comparison to a fully sealed IEM. Also, the frequency response of the music one is more focused on mids, and some on bass. According to Piotr (I talked to him about the prospect of my purchasing a music one) It sounds fairly similar to the Shure SE425 (which is cool, because it costs about the same, all told, I think). As such, according to many, I would guess that the Music One has some treble roll off. That assumption is backed up by the FR graphs on the CA website. If you look at the frequency response spec, it only goes from 10-18,300hz. That is certainly a pretty good FR spec, especially for a single BA driver, but you should note that that rating is a
+-20dB rating, meaning that there is a significant fall off there (as backed up by looking at the graphs, which show a significant drop beyond about 10khz).
^^^That being said about the Music One, Piotr gets massive props for posting not only the frequency response graphs, but also the equipment used, AND the SPL range used to determine the frequency response range. I appreciate that immensely. And I love that it's pretty much the second thing you see (after the picture, of course). That's absolutely awesome. I wish more companies would do this (looking at you 1964, especially since I know that you test the FR of all your in ears before you send them out)...
As far as the sound of the music one... |joker| has reviewed them, and they rank very, very highly on the headphone list (something over 9.7/10 in sound quality, if I recall correctly), especially considering that they are about $220 USD at sticker price (That means I'm not including impressions, options, or shipping.)
hopefully that helps?
Also, as for the HD800 and thunderous lows; Being that the HD800 is a flagship headphone, it is designed to have as flat a FR as possible, and the HD800 is one of (if not the) best measuring dynamic headphones in the world. Sennheiser really, really got it right. (Here is a rather cool powerpoint about flagship headphones. NOTE: It's rather harsh towards certain companies. I agree with it from a scientific point, however, I realize that many may find that I'm stepping on their toes. I don't mean to, I am linking it because I hope it helps answer some of the previous questions. Also, this is NOT my powerpoint. All credit goes to the original author (I apologize for not knowing who that is...)
