phonomat
- Jan 28, 2013
Haha, sorry, I just remembered I've asked you about this before. I need a Head-Fi break. Thanks anyway!
hi guys.
i was so troubled to choose which one to choose.
KSE1500 or 64audioTia Fourte.
personally i loved to listen classical music, instrumental and vocal more than other genre such as rock or EDM.
preferred no stack up required, while using iphone 7 or SONY NW-WM1-Z.
please kindly assist, thanks.
Shawn.
I think the Fourte is getting a lot of hype purely because of its price tag. If you want to avoid the electrostatic amp, check out the JH Lola or Beyerdynamic Xelento. To my ears they're both better-sounding (and cheaper) than the Fourte.
.... Tia fourte, the sound is similar with Layla2 with silver cable, yes the price looks hype for me. if only there a obvious difference i don't mind paying for that.
totally agreed with this issue.time will tell. We should read soon the first listening impressions from the happy early buyers of the Fourte.
I used to own the KSE1500 but sold it because I was feed-up with multi boxes set-up (A&K + Mojo + Shure)
i have tested KSE1500, Zeus XRA, A18Tzar and Tiar Fourte.Time will NOT tell if the Fourte is good. Only trying it will tell. Because 64 will certainly have "encouraged" some reviewers to praise it, and those who bought it will have 3600$ worth of bias.
fedup with multiple set-up.
simply annoying, ended up i choose Tia fourte with PWaudio 4 wired.
hiDear sir,
Do you have pictures of your Fourte and PWaudio 4 wired ? or just the PWaudio 4 wired cable ?
Where did you buy this cable ? is it all silver ?
thanks
hi
tia fourte currently shipping will reached singapore by mid of may.
is PWaudio 4 wired cable not intergrated.
i bought it at music sanctuary in Singapore, yes is a silver cable.
Will you ever have a chance to pair it with Currowang soundaware M1Pro? I think maybe a warmer sound pairs better with KSE1500.
The NW-WM1Z doesn't have a line out. I've not been able to get a proper/decent volume output match from the NW-WM1Z to the KSE1500 even with various combination settings (even playing around with input pad).
A DAP with a proper lineout is a better match - e.g. something like the iBasso DX200.
