Has anyone tried the m1060s with the Aune X1s? If so do they pair well?
Yes, but I disliked the Aune. It is too bright for my taste, too technical and not musical enough. Even ruined the hd600 for me.
Awesome! That's how I have mine set up now. Did you do the 3inch paper mod as well?I kept the felt to keep dust and stuff out but I switched back to leather. I bought the magnetic adapters to test both pads but decided to ditch them and just use the double sided tape. Preferred the sound w the stock felt and leathers.
Ah I see, I had already ordered the Aune and it's on its way. I generally like a bright sound sig so I'm hoping I would like the pairing, if not I may add a tube amp or something down the lineYes, but I disliked the Aune. It is too bright for my taste, too technical and not musical enough. Even ruined the hd600 for me.
From what I've read online the nfb-11 and the m1060 seem to be a match made in heaven. I haven't hear the nfb-11 myself though. I had considered the nfb-11 as well but considering the ordering process and the additional cost of the nfb I instead settled on the Aune.I'm looking into buying the NFB 11.28 for the m1060's, was wondering if there are any better options for dac/amps at around $300?
Awesome! That's how I have mine set up now. Did you do the 3inch paper mod as well.
We're sorry for the late reply, we experienced a large influx of emails and are catching up. \
Unfortunately we do not have the earpads for those headphones.
The driver size is 56mm so you would want to search for earpads that are that size.
Sorry for any inconvenience this may have caused.
The following Customer(s) have been CC'ed:
I took the paper out after I attached the leathers. It made the sound a little muffled, they paired best with the vegans.
I have the previous NFB-11 (9018 chip) and absolutely love it. Great with the M1060s for sure. I definitely think it is the best dac/amp combo option in that price range. Many people believe it competes well with other solid state amps in the $1,000+ range as well, but I haven't compared those personally. It is built like a tank, the pot doesn't have any channel imbalances, it can power almost every headphone except maybe HE-6, and it has all the possible input and output options you could want. I particularly like it with M1060 because planars require higher current and more current control (as opposed to voltage in high impedance dynamics) and Audio-gd implements a current conveyer topology with less gain stages and more current (and voltage) control. I know the hassle of waiting to have it hand built in China is a pain, but you won't be disappointed if you go that route.
So I emailed Monoprice asking if they had earpads I could buy as replacement earpads for my M560. I didn't want to cut up the original earpads to use the magentic plate with something else. This was the response I just got back from them after over a month of waiting for their reply.
Sony XB500 pads and 4 pieces of double sided tape on the housing itself is working fine for me. Light use though
So, does these still have something to offer if one already owns the HE400i, HE560, HD650, HD700, X2 and Q701?
My preference is more towards the Hifimans and HD700 than the HD650.
