Is this the definitive MHDT DAC thread? I'm considering getting one.
How many folks here have compared them to some of the other R-2R NOS DAC offerings?
The only I've owned is the Audio-GD NOS1704. Sounded great but was a little syrupy/soft for me.
The Master-11 I have now can run in NOS mode and sound excellent as well, but much more detailed than the above.
I'm looking for a NOS R-2R DAC for my work setup. Considering a DAC-19 and going NOS with it, but more recently (after failing to buy a Paradisea 3 from
@Soundsgoodtome), I've been looking at MHDT, Monarchy, and some other DACs.
The Havana 2 DAC isn't what I would call "syrupy" ... it is certainly a NOS/R2R design, and a well realized one in that it is on the warm side of the DAC spectrum with just gorgeous musicality and a non-fatiguing signature. The MHDT Labs Stockholm v2 is technically a better DAC, continuing the musical ease evident in the Havana DAC but being a bit more resolving and detailed. Both the Havana and Stockholm v2 DACs use the venerable PCM56P DAC chip (x2 in dual mono) and so even though capable of receiving input up to 192/24bit, they are both nonetheless limited to 16bit output (a simple limitation of the PCM56P chips). They are both excellent DACs and that statement is echoed in many glowing reviews both here and online in general; you'd be hard pressed to find anything online in the way of negative comments regarding either one.
That said, I've been fortunate enough to have a MHDT Pagoda DAC in my house for the past few months and can say it's a bit of a departure from both the Havana 2 and the Stockholm 2 DAC.
(that vertically aligned bit of gear in between the DACs and my amp is a Mapletree switch box that lets me instantly switch (A/B) between DACs while listening; very handy for comparisons...)
Though still a very musical, very classic sounding NOS/R2R design, the Pagoda DAC uses dual PCM1704 DAC chips in it's circuit as opposed to the PCM56P chips used in both of the above two mentioned DACS; this alone creates quite a different sound signature. The PCM1704 chips in the Pagoda produce a much more detailed sound overall with markedly more sparkly highs, slightly tighter bass and a more spatious, more airy sound stage presentation overall ... the PCM56P chips in the Havana 2 and Stockholm 2 on the other hand yield a slightly more musical, warm presentation that doesn't give quite the 3 dimensional imaging of the Pagoda. I've been A/Bing the Stockholm v2 and the Pagoda DACs quite often for the past few months (in preparation for a review) and the differences are quite obvious. I love them both but I think either would best suit particular listeners with particular needs.
Further, due to the usage of the PCM1704 DACs, the Pagoda can receive input up to 192/24bits and can maintain that 24bit stream all the way through output; it is a true 24bit capable DAC and when playing high resolution files, this makes a huge difference. Clarity goes through the roof and detail/micro detail retrieval, sound stage and imaging really reach the "spooky" level. Another interesting bit of trivia is that, a
ccording to my reading online, the Burr Brown PCM1704 is the only option currently available for the construction of non-oversampling, true 24bit digital to analogue converters. It's today still recognized among many builders as the finest sounding, most musical DAC chip available today (some interesting reading regarding the PCM1704 can be found here: Lessloss comments on PCM1704.
I listen to primarily Redbook resolution FLACS and so the high resolution dexterity of the Pagoda isn't that important to me. But even with Redbook listening, the Pagoda is a noticeably more resolving DAC ... as mentioned, that difference coming through mostly in noticeably more sparkle in the highs and a more airy/3D presentation.
I listen through Grado PS1000's and I think I ever so slightly more enjoy the Stockholm 2 with them since the Grados are already high frequency sensitive but at times, and with other headphones, I prefer the more articulate, detailed Pagoda DAC.
Judging from your comments in your initial post, I would recommend trying to hear a Pagoda DAC if at all possible... sounds like exactly what your looking for.
BTW: here's a handy spreadsheet showing the technical differences among all the MHDT DACs. You will note that both the Havana and Havana 2 still use operational amplification (OPAMP) in their circuit and so among all of the offerings, they are going to be the warmest and otherwise lack some of the overall resolution and clarity of the upper end DACs:
MHDT Labs DAC Families
Best,
Joel
