v1rt
- Mar 9, 2015
I'm not a super expert on the past versions of the HE400i, but yes there is one general difference: past versions used to feature twist-to-lock F connectors in the detachable cables. Now the HE400i uses the more traditional (and more practical) 2.5 mm jacks.
I think there were also versions along the way with differences in the grill, though I can't begin to tell you how, when, and what differences it makes. I only have the new version with the 2.5 mm jacks, none of the other past iterations.
Hope I've helped!
Looks like the one I saw in Amazon is screw based? https://images-na.ssl-images-amazon.com/images/I/51aD4mpRrqL.jpg
Is that screw based? The pic is bit blurry so I can't tell if that is a new model. I took that pic from https://www.amazon.com/HIFIMAN-HE-400I-Full-size-Magnetic-Headphones/dp/B00MULH672/ref=cm_cd_al_qh_dp_t
