Ang Probinsyano
- May 1, 2017
Another question. Does the stock cable have a memory wire. I'm searching this for awhile and some have memory wire, others don't.
My stock cable doesn't, but the silver upgrade SE has it and silver update balanced not. I am not worried about it.Another question. Does the stock cable have a memory wire. I'm searching this for awhile and some have memory wire, others don't.
Last question, what's the difference between the flc8 and flc8s? can't find it on google
Found it. The flc8s has twisted cable while the flc8 has different cable. Just making sure, I'll be receiving the 8s. Thank you guys.
If I'm not totally wrong, the FLC8-non-S had some filters that were different.
In my particular case, while bass is the same, mids are clearer and highs slightly brighter. I am sticking with red-grey-green and I love the combination.What's the specific difference between FLC 8s' stock cable to LMUE's Single Crystal Silver Cable upgrade when it comes to sound quality alone?
Hey I just got my cable from Penon:
https://penonaudio.com/2-Pin-0.75mm-4-Core-Earphone-Upgrade-Cable
It fits FLC8s fine, I don't plan on changing the cable often though, so YMMV. So if you are fed up with the stock cable, this is an alternative.
how is the sound against stock cable?
I don't notice any change in sound. The fit is so much better now due to the softer cable and the lack of memory wire, the stock cable keeps getting in the way.
