Hawaiibadboy
BANNED
Still have not touched EQ and likely will not.
My pics are all same angle. Good screen, reflection, warmth to it.
Review will have other shots and vid review will have the whole shabang
Playing from Fiio Player or Android Music Player App ?
@Hawaiibadboy
if possible. pls compare its line out with that of x5 in your review.
generally i keep one dap at a time and make it centre of my system, feeding different portable and desktop amps. so line out performance is important.
Do you think X5 III sounds better paired with A5 even with sensitive and balanced IEMs ?I can do that.
I like the X5iii line out to the A5 better than without so i will compare them doing that
I can do that.
If no improvement using A5 if with IEMs, can you also compare X5 III alone with balanced IEMs vs X7 + AM3 with balanced IEMs ?
I used to use my X5 I paired to E12 too... But with my sensitive new Togo334, E12 is noisy. And I thought, X5 III was good enough without amping with sensitive IEMs... So the comparison with X7 II + IEMs should be done with "X5 III at it best...", with or without amping I don't know...Great. Thanks a lot.
I am still rocking fiio x5 classic e12 rig. Cant listen with out e12 regardless of hp or iem used.
Dunno how improved hp stage of x5 iii is. But on classic its ridiculously bad. Especially compared to how good line out is.
Anyway, it cannot be with A5 as it has no balanced headphones out. Maybe A5 II, or A6...
Is this available in the UK yet?
Two dates mentioned by UK suppliers, 29th and 31st July
Hi
I don't know if anyone can answer this at this early stage, but is the FiiO A5 amp good enough to be used with the X7ii in place of its own higher powered amps?
Regards
Darren
