JWolf
- May 3, 2005
Onkyo sounds better to me than fiio player,
Have you heard the X7II?
Thanks for testing. Have been burned by Fiio X7 once, very cautious this time. Are they MP3 or flac? Thanks for your time.
Never tried DLNA in my life but. Using Windows 10 built in service through the control panel it is working fine with This FiiO X7II
I see what you mean. Read up a lot of bugs that aren't 3rd party app related. But advertised features for x7. Fiio has not fixed them since it's launch two years ago.Thanks for testing. Have been burned by Fiio X7 once, very cautious this time. Are they MP3 or flac? Thanks for your time.
omg, that is annoying, it does that too on Aune M1S. But in random order, all bad XD.To the members giving initial impressions, can you detail if the alphabetical order of the files listed in FOLDER view, is correct. On the X5III, alphabetical order is pretty screwy.
Hmmmm, ok, what about this, does the X7III firmware allow for viewing long filenames, without truncating the filenames or the folders. Sometimes on the X5III, in folder view, the files are truncated, basically making some folders indiscernible
dsrk said: ↑
Don't believe in them reviewers. I did a side by side comparison to an AK380 & X5 3 and it did come close in SQ and it costs a fraction of it's hefty price. Don't just listen to others, just listen to yourself.
You never know what you would like!!!!
:c hopefully X7ii might help close that gap.I don't think you understand, i personally own an ak320, and it's SQ is far superior in my opinion. To me, the SQ is night and day difference between the X7 and the AK320.
The Folders appear to be in perfect order
The long file names are 3-4 words then truncated (...) with 2 words at the end
When playing they scroll full length left to right under the progress bar.
It also scrolls in the mini widget that is at the bottom of the screen (top image)
nice to hear your input too!X5III doesnt sound like the X7. X5III is on par with the AK320 and surpasses it with some Android Music Player Apps.
