kvn864
- Aug 6, 2015
yes, its like $5, and solves usb problems
Is that with the 11.32 or 11.28? I get a lot of blue screens with my 11.32 and if this issue is also present with the 11.28, I'll push for a refund rather than an exchange.Now windows likes to give me blue screens for audio connection errors like that's necessary
. Drivers have never been an issue for me with the Amanero's. -Are Yo
Hello,Hi,
I have the Amanero384Combo interface in 6 different gears. The only issue I have experienced was one module that "decided" to be instable with a bad habit/behavior with dropouts in some higher quality material. The module was replaced and voilá, problem was solved. Drivers have never been an issue for me with the Amanero's. -Are You sure Your computers are in a healthy condition? -Not polluted by regretted driverinstallations? For me, working flawlessly in both linux and Win10 64 bit.
The Amanero gives a very high performance when working proporly and it is worth trying quite hard to get it to work. The sound quality rewards the efforts, I'm sure. Don't give up too easy.
/Jan
If your source is PC and you have optical out, use that, the option works well, and optical cable is $5 on ebay, I see no other choice.Any solutions to the problem with the es9018 model?
Yes, the DAC from your PC's soundcard is bypassed when you're transmitting digital signal via optical cable.Interesting. Does that bypass the dac though?
EDIT
Upon some reading I now realize that my question is probably dumb. Since toslink transmits digital signal then digital to analogue conversion is not taking place (in the soundcard) so the dac is not involved. Is this correct or there's more to it?
Francisk thanks for the confirmation. Are there any disadvantages in using the optical connection of the NFB-11 instead of USB?
