Cavalli Audio Liquid Carbon Now Available
Apr 13, 2015 at 6:28 PM Post #16 of 1,195
Still didnt answer my question? I will change it. Do
I have to register tomorrow at noon and then purchase, or can I purchase as a guest on paypal? I hope this is clearer,
as I can understand the first time not being understood.
Thanks
You can do all that tomorrow at noon Central...
Apr 13, 2015 at 6:48 PM Post #17 of 1,195
  Is there a list of specs available?
Specifications
  1. Gain: 1X (0db) and 3X (10db), hot switchable from front panel to adjust for different headphones
  2. Maximum Power: ~1.5W into 50R
  3. Inputs: 1 x XLR  (Bal); 1 x  RCA; 1 x 3.5mm - front panel selectable; RCA and 3.5mm are the same input.
  4. Outputs: 1 x 4-Pin XLR; 1 x TRS, 1 x RSA.
  5. THD: 0.004% at 1kHz/500mW (4VRMS) into 32 ohms (resistive)
  6. Input Impedance: ~10k
  7. Output Impedance: ~0.12 ohm Balanced, ~0.08 ohm SE.
  8. Size: 5" (W) x 7" (D) x 1.75" (H);12.7 cm (W) x 17.8 cm (D) x 4.5 cm (H)
  9. Weight: 1 lb, 7 oz (0.7kg)
From http://www.head-fi.org/t/761088/new-cavalli-audios-liquid-carbon-mini-desktop-amp#post_11429166.
Apr 13, 2015 at 6:54 PM Post #19 of 1,195
Exactly
Apr 13, 2015 at 7:01 PM Post #21 of 1,195
Yes, it would be helpful with this project if the website would allow us to do that, but the website will only ask you to create an account when you try to place an order.
Apr 13, 2015 at 7:03 PM Post #22 of 1,195
So if we try to fake a LAu order that would work?
