- Dec 17, 2012
I thought this was the standard connection arrangement for TRRS headphone jacks:
Are there different arrangements in use?
The one you show looks like the pin out for 2.5mm (AK DAPs).
Most of the 3.5 TRS/TRRS that I have seen have the pin as L(+), ring 1 is R(+), ring 2 (TRRS only) is L(-), sleeve is R(-) or common ground on TRS.
Have also seen "mic" in there on either ring 2 or sleeve depending on what standard is used (CTIA or OMTP).
So to answer your question, yes there are different ways to wire it up, you just need to know what standard applies.
