Theogenes
- Mar 28, 2010
Good thought. Yeah, I tried it on two of my phones and out of my D100. Same thing each place, so I don't think it's source dependent.
Okay, good to hear. The visions of a broken driver floating through my head did not exactly bring a smile to my face, so this (and the similar comments below) are very reassuring!
Thanks a lot, guys!! It will be a couple of days before I'm going to be able to do it with my work schedule, but I'll work up the courage to take 'em apart by then
ZombieX has a video on disassembling the T1 (here), would I be safe in assuming the T5p disassembly would work the same way?
Have you checked about your source or player?
About different volume between 2 channels, that can be cause by some factors like headphone positioning on your head, our ears condition (almost getting sick perhaps, flu is a very common reason also), etc
People have disassembled their T5p, apparently the T5p is made of modular components that all "click" together so you can probably check it out inside carefully. I used to get a buzz on the driver diaphragm when a hair somehow made it through to the driver. At the right low frequency it would get to buzz. I think someone yanked out the cable of one ear cup and someone managed to break the wire inside the cable also. Could all be a possibility. The very last resort for me would be sending them to someone.
EDIT: That was on my HD650's. Theogenes your T5p are likely have something minor going on, not broken.
Most common thing by far I've seen here at Head-Fi causing that kind of problem is a hair getting in there somehow (seen it pop up in many threads for a variety of headphones).
I am also guessing it is a hair or dust. It would be easy to remove if you take out the driver and remove it. DO not panic! We are here to help you
