sargaso
- Jul 1, 2011
As I am hoping to jump on the BA bandwagon and hoping to pair it with ZO what is its (ZO's) output impedance?
I measure zo's output impedance at 6.2 ohms.
Good luck with that - I was initially going to ship my ZO2 to Voldemort to see if he would run the dScope over the thing, but I've since realised how good it is with music and movies.
To anyone asking if the ZO2 will drive the RE262, as long as your source has a reasonable amount of grunt, the answer is yes. I am listening to this combination as I type this:
T51 -> ZO2V1 -> RE262
Its a good combination, IMO, but I've lost track of the gain situation with the V3 - the V1 has plenty of gain for the RE262.
The original ZO had an output impedance of 0.2. I doubt the new one would jump 6 ohms.
Any ideas , Who pays for the shipping(International) on returns ? I had sent mail to Zo2 support 8 days back had no reply.
They should cover shipping back to you. You just have to pay for shipping to them out of your pocket.
I don't have the original ZO to measure and I don't know if the changes they are currently making for the version 3 will change the output impedance, but the ZO2 version 1 that I had measured 6.2 ohms. Maybe they will put their measurements on their website for the ZO2 like for the original ZO but if they do I would bet that they would be for the final ZO2 v3 and not any of the in-between versions. I have previously measured the output impedance of the ibasso D10, TTVJ Slim, headstage Arrow 12he and some other devices and my measurement matched the manufacturers spec on all of them so I don't think I've made a mistake but nobody's perfect.
For shipping unfinished product ?
Thanks for putting in the time and effort to do this - can you tell us what gear you used to run the measurements ? (If only we all had a dScope and knew how to use it)
So no chance to pair it with BA IEMs as I've heard that you need the output impedance to be less than 1ohm. Correct or...?
...Using high gain with my TF10s offsets the balance.
