ZMF Verite Open
Jul 13, 2019 at 5:33 AM Post #2,386 of 9,534
Verite in the house
Can you weight them without the cable ? I ordered the same specs except a black chassis and I wonder if they will be too heavy.
Jul 13, 2019 at 8:37 PM Post #2,387 of 9,534
Without cable they are close to 540g
Jul 13, 2019 at 8:54 PM Post #2,388 of 9,534
Just enjoying this setup while at work
Jul 14, 2019 at 6:42 PM Post #2,389 of 9,534
Jul 14, 2019 at 7:23 PM Post #2,390 of 9,534
Damn that's heavy, can you bear them over several hours?
I have no idea how much my particular pair weighs,but theyre quite comfortable and I can wear them all day.
Jul 14, 2019 at 7:24 PM Post #2,391 of 9,534
I don't listen for long hours but the weight is distributed perfectly and the clamp of cups also takes some weight off.
Jul 14, 2019 at 7:27 PM Post #2,392 of 9,534
I am patiently waiting for my Verite to come in and was wondering if anyone has paired them with the Mjolnir 2 or has heard it with the new Ragnarok 2.
Jul 14, 2019 at 9:57 PM Post #2,394 of 9,534
@nishan99 supposedly the black rods and grilles are lighter. The leather strap definitely helps on comfort level. I have brass on my Ziricote and it doesn’t bother me one bit.
Thanks for sharing your experience. My heaviest headphones are the M1060 (500g) and I don't have weight issue with them at all, I just was a bit worried about that extra 40g but now I don't think so :)
Jul 14, 2019 at 10:28 PM Post #2,395 of 9,534
I have paired them with Mjolnir 2 and its sound great, but I like it more when pairing with WA8. I think Verite is best when you paired them with full tubes amp.
Jul 14, 2019 at 11:21 PM Post #2,396 of 9,534
What makes the Verite a better pairing with a tube amp as opposed to an SS one? Does it have more energy up top that needs to be tamed, any sharp spikes?
Jul 14, 2019 at 11:34 PM Post #2,397 of 9,534
I wouldn't say it sounds better, just a different presentation (and even then it depends on the type of tube amp). The Verite does sound great on most tube amps, but i also quite like it on some really good SS amps. The Verite isn't as amp picky as say the Atticus.
Also you won't find any treble spikes on the Verite either, regardless of amp.
Jul 15, 2019 at 1:04 AM Post #2,398 of 9,534
Agreed. I wouldn’t necessarily say it sounds “better” with a SS amp compared to tubes. My V281 really utilities the speed of my Vérités. I can definitely tell the difference in that regard. But there’s something about tubes where it changes the soundstage, the vocal presentation, instrument separation and so on. Again, as with all audio, it’s very subjective. I’ve had a few of my coworkers tell me they prefer the sound coming from SS.
Jul 15, 2019 at 10:40 AM Post #2,399 of 9,534
Music is like coffee everyone drinks it their own way...
Jul 15, 2019 at 11:25 AM Post #2,400 of 9,534
